3.2 with 914 transmission: sensor locations, Where do I cut the housing? |
Mitox |
May 18 2022, 07:22 PM
Member Group: Members Posts: 395 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
I’ve disassembled my 914 trans, so I can clean and paint the case prior to a rebuild. It will be hooked up to a 3.2 retaining the fuel injection and Motronics. Before it is painted I’d like to cut the notches needed in the case for the Motronic sensors, but I don’t have a clue where to cut.
Can anyone point me in the right direction, or better yet, have measurements or a template for the cuts. Thanks for any help you may have |
Steve |
May 18 2022, 09:05 PM
914 Guru Group: Members Posts: 5,596 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
All I did was slide the 914 gear box onto the 3.2 motor as far as I could and then mark with a felt pen where the trans hit the two sensors and cut out a notch with a dremel tool.
mepstein |
May 18 2022, 09:56 PM
914-6 GT in waiting Group: Members Posts: 19,286 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
All I did was slide the 914 gear box onto the 3.2 motor as far as I could and then mark with a felt pen where the trans hit the two sensors and cut out a notch with a dremel tool. I remember this is what we did when we notched my trans. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 07:07 AM |
