3.2 with 914 transmission: sensor locations, Where do I cut the housing? |
Mitox |
May 18 2022, 07:22 PM
Member Group: Members Posts: 395 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
I’ve disassembled my 914 trans, so I can clean and paint the case prior to a rebuild. It will be hooked up to a 3.2 retaining the fuel injection and Motronics. Before it is painted I’d like to cut the notches needed in the case for the Motronic sensors, but I don’t have a clue where to cut.
Can anyone point me in the right direction, or better yet, have measurements or a template for the cuts. Thanks for any help you may have |
Maltese Falcon |
May 20 2022, 07:37 PM
Advanced Member Group: Members Posts: 4,647 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
In the days of 3.2 Vanagon conversions, I used to send out a "Hard-Wire" template of the DME sensors cut out; this had a semi-circle bend to it which mates to the upper bell-housing bolt hole (locator). >>passenger side for the mid-engine (drivers side) for the Vanagon.
The opposite end of the Wire had the contour (DME sensor area) from a g50 or 915 gearbox, which just places down + sharpie the pattern. I just went to a friendly Independent Porsche shop and they let me make the pattern from a trans that was on a pallet. (IMG:style_emoticons/default/marty914.jpg) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:57 PM |
