| cgnj |
May 19 2022, 09:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 740 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
I have a Mid 80's 911 Boge strut housing part number 0 21 132 267. The threads are on the outside of the housing. I ordered B6 34-001127. It came with 914 strut collar, that is meant to thread into ine inside off the housing. The part number etched into the collar is 836 816 E2. Is there a way to order the correct co;;ar for a 911 strut housing?. Should I have ordered a 911 strut? Does anyone have the Bilstein part number?
Are the bump stops required or a delete? The installation instructions say delete. My rear coil over kit from Ground Control wants the bump stop cut down. Again is this a delete, cut in half? I had no bump stops in the rear. If required is is anyone aware of a supplier? Thanks in advace, Carlos |
| 914Sixer |
May 20 2022, 06:06 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,609 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yes you can get the correct collar from Bilstein. They will not be cheap.
| Superhawk996 |
May 20 2022, 06:45 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,180 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Yes you can get the correct collar from Bilstein. They will not be cheap. Maybe just sell the 914 struts here on forum and then buy proper 911 struts if the nut turns out to be cost prohibitive ? (IMG:style_emoticons/default/confused24.gif) bump stops are internal to the Bilstien damper due to inverted damper construction. |
| Shivers |
May 20 2022, 07:55 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,718 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I went and looked and 68' to 85' is internal threads. The 1986 (like in the ad) has the threads on the outside. Any chance your distributor would just swap them out? With boge /bilstein inserts the bump stop is built inside the insert. The cutting you read about was probably about a bilstein strut, the bump is inside but accessible.
https://www.partsgeek.com/catalog/1986/pors...rut_insert.html |
| mepstein |
May 20 2022, 09:41 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,997 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
When I used to order for the shop through SSF, the inserts came with both types of caps. When I've purchased retail, they only seem to come with one. I think the caps are about $30-35 but when I've needed them, I've done a wtb on pelican and can usually get them cheap.
As Superhawk said, no bump stops needed w/ bilstein inserts. |
Lo-Fi Version | Time is now: 15th November 2026 - 08:31 PM |
