Odometer repair info in a haystack - copy please? |
73kg2.0 |
May 20 2022, 01:52 PM
Newbie Group: Members Posts: 3 Joined: 12-October 19 From: Denver Member No.: 23,560 Region Association: Rocky Mountains |
Odometer repair info is in here somewhere, but I can't find it.
Can someone please copy the link here if you know it? Thanks! KG |
worn |
May 20 2022, 05:27 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
914sgofast2 |
May 20 2022, 07:25 PM
Senior Member Group: Members Posts: 614 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Look in the Lapuwali Classic Repair section of the 914 Forum for the info thread. However, if the speedometer needle works but the odometer mileage counters don’t work, there are two (2) possible failure points: (1) the odometer drive gear has gotten loose on its shaft and is slipping, or ;(2) the speedometer body support arms for the odometer gear shaft have worn oval and the gears don’t fully mesh anymore. If the problem is #(2), then you need another speedometer that isn’t worn out or you need to send yours to someone lime Palo Alto Speedometer for a rebuild.
76-914 |
May 20 2022, 07:27 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
73kg2.0 |
May 23 2022, 02:34 PM
Look in the Lapuwali Classic Repair section of the 914 Forum for the info thread. However, if the speedometer needle works but the odometer mileage counters don’t work, there are two (2) possible failure points: (1) the odometer drive gear has gotten loose on its shaft and is slipping, or ;(2) the speedometer body support arms for the odometer gear shaft have worn oval and the gears don’t fully mesh anymore. If the problem is #(2), then you need another speedometer that isn’t worn out or you need to send yours to someone lime Palo Alto Speedometer for a rebuild. Appreciate the tip. Speedo works. |
73kg2.0 |
May 23 2022, 02:35 PM
Thanks much. Got the Pelican article. Seems they still have to upload or reload images. Pelican is typically very good at this. |
dr914@autoatlanta.com |
May 23 2022, 03:07 PM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 8th May 2024 - 12:27 PM |
