Odometer repair info in a haystack - copy please? |
73kg2.0 |
May 20 2022, 01:52 PM
Newbie Group: Members Posts: 3 Joined: 12-October 19 From: Denver Member No.: 23,560 Region Association: Rocky Mountains |
Odometer repair info is in here somewhere, but I can't find it.
Can someone please copy the link here if you know it? Thanks! KG |
914sgofast2 |
May 20 2022, 07:25 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Look in the Lapuwali Classic Repair section of the 914 Forum for the info thread. However, if the speedometer needle works but the odometer mileage counters don’t work, there are two (2) possible failure points: (1) the odometer drive gear has gotten loose on its shaft and is slipping, or ;(2) the speedometer body support arms for the odometer gear shaft have worn oval and the gears don’t fully mesh anymore. If the problem is #(2), then you need another speedometer that isn’t worn out or you need to send yours to someone lime Palo Alto Speedometer for a rebuild.
Lo-Fi Version | Time is now: 19th May 2024 - 12:32 PM |
