Can Too Much Oil Damage Your Motor?, Mechanic Added Too Much |
windforfun |
May 20 2022, 02:33 PM
Senior Member Group: Members Posts: 1,809 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Ran it for about 1 hr prior to draining excess oil. The motor is a "73 1.7. Thanks.
Puebloswatcop |
May 21 2022, 02:21 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Most likely no significant problems. It will generally end up in the cylinders and make sludge. If it seems like it's not running smooth, pull the plugs and see if they are oil soaked. If they aren't and you're not showing signs of excessive blue smoke from the exhaust, you should be fine.
Lo-Fi Version | Time is now: 27th May 2024 - 12:02 AM |
