Can Too Much Oil Damage Your Motor?, Mechanic Added Too Much |
windforfun |
May 20 2022, 02:33 PM
Senior Member Group: Members Posts: 1,809 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Ran it for about 1 hr prior to draining excess oil. The motor is a "73 1.7. Thanks.
emerygt350 |
May 22 2022, 10:40 AM
Advanced Member Group: Members Posts: 2,120 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I just noticed the difference between a mobil1 filter and a kandn which was shorter by a good inch. Oil runs hotter with the shorter filter but that may just be random chance and seasonal change. Going to switch back to the Mobil in a little while and see if that changes. I like the higher temps I am seeing with the shorter filter. Could be seasonal though.
porschetub |
May 22 2022, 04:45 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I just noticed the difference between a mobil1 filter and a kandn which was shorter by a good inch. Oil runs hotter with the shorter filter but that may just be random chance and seasonal change. Going to switch back to the Mobil in a little while and see if that changes. I like the higher temps I am seeing with the shorter filter. Could be seasonal though. Why not just use OEM filters ? ,I do that will all my VAG cars and never had an issue,I use the larger capacity OEM ones on T4 and my 911 motor in my 73 914. My experience overfilling a T4 resulted in excessive fuming and oil burning..not good,with a 911 it is even worse as you as you can blow seals and the motor will smoke continually and not just on cold start which to a point is normal. |
Lo-Fi Version | Time is now: 27th May 2024 - 05:15 AM |
