Heat and BANG, How did that happen?!?!?!?!?!?! |
ctc911ctc |
May 20 2022, 02:35 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74 914, all stock, near all original, 22k
As we all know getting the brake hose disconnected from the hard line can be a pistol on older cars, Heat always works, while doing the front end of the 914 (shocks and bushings) I am replacing the hoses - of course\ I needed to heat and started to torch (IMG:style_emoticons/default/blowtorch.gif) this connector when BANG! Turns out there was a very tight fit between the hose and connector, enough to hold pressure to an explosion point. Who Knew!?! Fortunately, I was wearing goggles. No, there were no blocks within the hose, this was not from what was IN the hose but between the hose and the connector. |
GregAmy |
May 22 2022, 07:03 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
A line filled with clean brake fluid should not have done that, unless you heated it for a long time and the fluid boiled. Any chance there was water in there?
And if anything, if the line wasn't blocked the pressure should have bled back into your master. Still probasbly not a good idea to heat that muc. Next time crack the bleeder so the pressure can escape. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:02 PM |
