Windage tray case saver |
Geezer914 |
May 21 2022, 08:31 AM
Geezer914 Group: Members Posts: 1,384 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Saw this on You Tube incase some one over tightens the oil screen bolt or adds a tuna can.
Mark Henry |
May 21 2022, 11:29 AM
If you have to take the case apart... repair it proper or replace the case.
It would need 3 legs to sit square. |
914werke |
May 21 2022, 12:31 PM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
A better solution is using some sheet for dbl. duty. Support preventing the bolt hole cracking + oil control limiting slosh.
Geezer914 |
May 22 2022, 05:11 AM
This is not a fix if the bolt hole in the case has cracked. This is to add support to prevent it from cracking.
914werke |
May 23 2022, 12:36 PM
This is not a fix if the bolt hole in the case has (already) cracked. This is to add support to prevent it from cracking. (by those who cant use a torque wrench) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/happy11.gif) Attached image(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 10:11 PM |
