If you have to take the case apart... repair it proper or replace the case. It would need 3 legs to sit square.
914werke
May 21 2022, 12:31 PM
A better solution is using some sheet for dbl. duty. Support preventing the bolt hole cracking + oil control limiting slosh.
Geezer914
May 22 2022, 05:11 AM
This is not a fix if the bolt hole in the case has cracked. This is to add support to prevent it from cracking.
914werke
May 23 2022, 12:36 PM
QUOTE(Geezer914 @ May 22 2022, 04:11 AM)
This is not a fix if the bolt hole in the case has (already) cracked. This is to add support to prevent it from cracking. (by those who cant use a torque wrench)
