| Joe Ricard |
Aug 3 2005, 07:36 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
So while I was laying there under my car (I just do that) while swapping out the transaxle I noticed something.
I looked down the SSI pipes and saw nice clean (like perfect burning plug color) from the exhaust port all the way to the line where the heat shroud stops. After that the pipe is black or very dark brownish black out to the flange. So would wrapping the rest of the pipe in header wrap maintain the heat and extend the better burn all the way through the pipe? Also will wrap the Bursch collector pipes. Bottom line will it make more power! |
| Jaiden |
Aug 3 2005, 07:56 AM
Member ![]() ![]() Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
Be very careful with heat wrap on a car that leaks any oil.
I have a wrx and frequent the wrx boards and one of the things we do is swap out up and down pipes on the turbo. One of the biggest problems with heat wrap is that when covered in oil it turns into a wick. There have been several Wrx's that have burned up and it is almost impossible to put out the fire on oily heat wrap. If you do decide to do it make sure that that you seal your heat wrap. I mean use the entire can of sealer on it evern if you think it is too much add more. The good thing about heat wrap is that it will definitly reduce the temps down there! |
| Joe Bob |
Aug 3 2005, 07:59 AM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Screw the oil....header wrap also absorbs water and rusts....just what ya need on a 914, more fuching rust....
| Joe Ricard |
Aug 3 2005, 08:21 AM
So it don't leak oil (check)
Bursch is rusty anyway Will it gain more power? Yea the cooler trunk temps will be nice while carrying race rubber tothe events. Attached image(s)
| URY914 |
Aug 3 2005, 08:26 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,371 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Joe,
All the F1 teams preheat thier tires before the race so having your tires in the trunk getting hot is a good thing. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Happy Birthday, you old fart. Paul |
| Brett W |
Aug 3 2005, 08:45 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None
Don't bother if you have stainless HEs. The thermal properties of stainless steel is much different than the mild steel. Stainless will hold more heat in than even a coated mild steel piece. SO wrapping your stainless pipes will gain you little.
GO to a header it will be worth it. I got your cheese, so I'll try and get the wheels shipped by the end of the week. |
| Joe Ricard |
Aug 3 2005, 08:51 AM
Good point. Thanks Brett. The plans for the yellow car is to sell it before XMAS. Definately a header on the stripper. Guess we need to talk about what else you got for parts. |
| Brett W |
Aug 3 2005, 11:58 AM
What else you need. I am quickly running out of cool, fast high performance four cylinder parts.
| nocones |
Aug 3 2005, 03:30 PM
Sportscar lunatic ![]() ![]() Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
Selling the racer!?!? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
That's one of my favorite teeners on the board. (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) Sure hope the 'stripper' is going to be as cool. |
| bondo |
Aug 3 2005, 04:18 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Haha, I've been there.. My mustang has a power steering hose that would repeatedly get damaged by exhaust heat.. so I wrapped it in header wrap. It was fine until it got oily and I made a u-turn.. it hit the exhaust long enogh to ignite.. I managed to put it out by whacking it with a catalog I had in the car. I have since secured the hose in such a way that it stays away from the exhaust no matter what way I turn. Still leaks tho. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
| Cap'n Krusty |
Aug 3 2005, 04:35 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The "burn" takes place in the cylinder, NOT in the pipes. If the factory engineers had thought they could wring more power by wrappint the pipes, they'd have done it. It is, afterall, cheap to do. Frankly, I think the idea is wacked. The Cap'n |
| ArtechnikA |
Aug 3 2005, 04:39 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
how big is your turbo? no turbo? no more power. |
| nebreitling |
Aug 3 2005, 07:35 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
Cap'n, are you disputing that a wrapped header can make more power? seems pretty damn accepted in hot-rod/circle-track world. from what i understand, it has to do with scavenging and underhood temperatures (the latter being less of a concern w/ a T4/F6)... i can think of a lot of reasons why someone (ie an engineer) wouldn't wrap a header, and only a few for why some one would. but it seems to me that "small power gain" goes under the category for running the wrap. i don't run one only because of the fire hazard. |
| nebreitling |
Aug 3 2005, 07:40 PM
btw, thermal coating is the way to go in any case.
| Maltese Falcon |
Aug 3 2005, 08:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,224 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Send the exhaust to a good ceramic coater...I use Xtreme (805-388-9983). They will blast, prepare , coat and cure the complete exhaust system. This will give you years of rust free use, lower under -car temps, and keep the exhaust moving out of the engine quicker. Header wrap basically does the same thing, with the exception of accelerating the carbon out of the c/r steel and therefore disintegrating the pipe. I've seen this happen in only 6 mos. use.
Header wrap also voids many mfg's warrantys , including ours (msds) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) MF |
Lo-Fi Version | Time is now: 17th April 2026 - 06:03 AM |
