WTB: 911 early clamping nut, 911.341.673.00 M 18 x 1 |
914werke |
May 23 2022, 07:37 PM
"I got blisters on me fingers" Group: Members Posts: 10,081 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Im finding I have a mismatched set of early Strut housings.
The EARLY - early struts used a smaller 16mm clamping nut & the later/early struts switched to a larger 18mm nut. (IMG:style_emoticons/default/dry.gif) Both are the same 3" caliper bolt spacing, late ball joint & inside threaded cap. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/bye1.gif) |
bdstone914 |
May 23 2022, 09:41 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Im finding I have a mismatched set of early Strut housings. The EARLY - early struts used a smaller 16mm clamping nut & the later/early struts switched to a larger 18mm nut. (IMG:style_emoticons/default/dry.gif) Both are the same 3" caliper bolt spacing, late ball joint & inside threaded cap. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/bye1.gif) I have a few of them. @914werke |
914werke |
May 24 2022, 12:03 PM
DoH! I guess I need the bearing plate (washer) as well since the ID is bigger. (IMG:style_emoticons/default/dry.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 10:07 PM |
