Im finding I have a mismatched set of early Strut housings.
The EARLY - early struts used a smaller 16mm clamping nut & the later/early
struts switched to a larger 18mm nut.
Both are the same 3" caliper bolt spacing, late ball joint & inside threaded cap.
