first race of the season |
brant |
May 24 2022, 11:27 AM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
A week back, I attended a vintage race in colorado
the car did fine... the driver was slow, but still had fun a couple of shots I ran a staggered set of bias- ply vintage tires... car was not aligned for them... and they were a bit underwhelming... Attached thumbnail(s) |
wndsrfr |
May 24 2022, 11:42 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Tough to get enough meat on the track on a non flared setup. What age were the tires, what sizes...looks like 15 inch rims...
johnhora |
May 24 2022, 12:00 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
"Driver Slow"....Nothing like the first race of the season to get the cobwebs out of the ole driver and with a new setup added to the mix...You look good buddy...have fun this season!
brant |
May 24 2022, 12:02 PM
I'll have to pull the sizes.... the hoosier TDR tire in 15inch
a year or more old... just wanted to run them for a full event and see if I could adapt. I can get 8 inch fuchs under the back easily but class restricted to 7inch rims. typically run a 225/15 on 7inch rims with a 1 inch spacer for track (because I have the room) I only ran a 3/4 inch spacer on these... due to the balloon sidewalls. fenders are modified....just as wide as a flared car plus this is a low HP 2.0 motor so plenty of traction in a straight line. |
wndsrfr |
May 24 2022, 04:35 PM
I'm on 15's...Hoosier TDR 7.5-23-15 front and 8.5-24-15 rear. Start at 17psi finish at 22. Car is faster than the driver which is a good thing....I think??
brant |
May 24 2022, 04:47 PM
You motivated me to go to the trailer
Same size and tires front and rear as you Thanks for the input on pressure I think I was at 19psi Sunday afternoon I got frustrated with the tires and put on a 6-7 year old/45??? Heat cycles. Set of 225/15 A7 tires and pulled a half second off my times Just having a hard time liking them They recover well from small slides. But they slide way to easy at turn in What did you do for alignment numbers? With these? I tested them for one day last year and went back to the speedsters Decided it was time to give them a second chanceā¦. But still not loving them Wish I had dropped the pressure in hindsight |
GregAmy |
May 24 2022, 08:41 PM
Advanced Member Group: Members Posts: 2,308 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I run Hoosier A7/R7s on my "regular" race car but most historics groups don't allow them.
I've run Hoosier Speedsters on my historics 914 ride and I just don't like the tread squiggle. So my recent "go to" has been Nitto NT-10 DOT 100TW tires. They're a good construction, very responsive, and wear nice. I'm moving to Conti 200TW DOT Extremes. Sure, they're not as fast as A7s (or possibly even not as fast as Nitto NT-01 100TW) but I'm a Hoosier butt-boy and I think they're a good choice. After all, this is historics racing, not LeMans. For comparisons of radial DOT tires versus "radial slick", we've tested Hoosier A7 245/40-17 and 265/630-17 M compound Hoosier same weekend (the "real" race car) and I honestly did not notice a significant difference in lap times and/or driving characteristics. I wish I could have tested them blind but I'm the one that had to swap the tires, so... I personally don't like the way bias-ply slick tires drive. I've found the 914 chassis to be much more responsive on radials, with less slip angle required and a lot more total grip. But note I've been racing on DOT radials since the 80s, from Showroom Stock through various iterations of touring cars. I find the DOTs easier to drive and easier to set up the car. But of course that's a personal preference. - GA |
ValcoOscar |
May 24 2022, 09:14 PM
Garage Life Group: Members Posts: 2,386 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
A week back, I attended a vintage race in colorado the car did fine... the driver was slow, but still had fun a couple of shots I ran a staggered set of bias- ply vintage tires... car was not aligned for them... and they were a bit underwhelming... Poster quality photos... (IMG:style_emoticons/default/first.gif) Keep (IMG:style_emoticons/default/driving.gif) Oscar |
wndsrfr |
May 25 2022, 06:38 AM
I'm at just under 2 degrees negative both front and rear with about 1/16 inch toe in. I'm no expert but watch the edge wear and temperature profile to decide if change is needed....
brant |
May 25 2022, 08:59 AM
Lo-Fi Version | Time is now: 25th May 2024 - 09:07 PM |
