| SteveL |
May 25 2022, 11:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 666 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None
I have an old high-power Sony CD deck in the car now, and some old blown out speakers.
I am not looking for great sound, just decent. Able to hear music with the top off without it being distorted. Don't want anything too flashy on the dash, and using factory speaker boxes. Receiver: Pioneer MVH-S322BT Watts Per Channel 50 watts RMS Power 22 watts https://www.bestbuy.com/site/in-dash-amazon...p?skuId=6362270 OR Alpine UTE-73BT built-in MOSFET amplifier (18 watts RMS/50 peak x 4 channels) crutchfield.com/p_500UTE73BT/Alpine-UTE-73BT.html?mfr=&fromlanding=1 With these speakers: Infinity Kappa 4"x6" 2-Way Loudspeakers https://www.amazon.com/dp/B00FP3IKW2/ref=ps...1_t1_B07657R646 OR Pioneer - 4" x 6" - 3-way https://www.bestbuy.com/site/pioneer-4-x-6-...p?skuId=6454571 Thanks |
| Big Len |
May 25 2022, 12:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,792 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
I have the Alpine model you asked about. It's a good unit, sounds much better than my JVC head unit, and is easy to navigate. The Pioneer looks good too for the similar price range.
The speakers are a bit easier as I would go with the Infinity's. Better sensitivity and they're typically bass strong. I like the Pioneer speaker because of the directional tweeter. Alpine and Infinity. |
| 914Sixer |
May 25 2022, 01:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,606 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
What grills are you using for speakers? Stock grill speaker holes are 100mm x 100mm for mounting. Most 4x6 will need some sort of plate.
| FlacaProductions |
May 25 2022, 01:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,295 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
If you haven't already, a lot of info here - do a search and pay attention to what bbrock did.
| JmuRiz |
May 25 2022, 09:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,654 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
I have kappa 4x6 plate speakers (older version of what you are looking at) and used them in stock grills w/o modification.
| SteveL |
May 26 2022, 06:51 AM
| JmuRiz |
May 26 2022, 09:02 AM
Just a head unit...they were OK, but I did add a pair of up-firing 3.5" 2-ways in a custom center console. That helped a LOT with top-off driving. At one time I had a 150w powered 6.5" bazooka just in front of the passenger seat too.
I've been rebuilding the car the last 10+ years and will go with 6.5" low profile in the 914rubber pods, stock location. Probably keep my 3.5" center 'armrest' console and a new super thin Pioneer sub mounted behind my engman passenger side foot rest. So we'll see how much better that will be (IMG:style_emoticons/default/smile.gif) |
| Chris914n6 |
May 26 2022, 01:48 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,565 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I have an older version of those Infinitys. No low end whatsoever, so I bought the 6.5" speaker housings and 2-way Kappa 6.5". Paired with a Soundstream pn4.520d and half a JBL Fuse.
Of your choices, you would probably be happier with the Pioneer 4x6. At 30w rms either deck will be plenty loud. Cone area should let it play a little deeper. As long as it has a high pass filter to cut the low <80 hz frequencies. |
Lo-Fi Version | Time is now: 8th November 2026 - 11:30 PM |
