SOLD: Defrost rear window: $100 obo plus shipping from 94952, Needs one connector repaired |
tygaboy |
May 30 2022, 03:11 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Defrost rear window. One connector is missing, as pictured.
This can be repaired. See Brent's thread where he did this very thing. I can't guarantee the defrost works, as I never had it installed. But there's no reason to believe it won't. It looks in good shape, other than that connector. I'm just trying to be transparent. ( (IMG:style_emoticons/default/lol-2.gif) ) I don't have the wiring harness, or switch, just what's pictured. @bbrock Brent, any chance you could post your pic or add a link to your thread where you did the connector repair? Appreciated! Attached thumbnail(s) |
914Sixer |
May 30 2022, 05:58 PM
Take a volt ohm meter and test each line side to side. IF you see a solid short the grid is good.
bbrock |
May 30 2022, 07:45 PM
Brent, any chance you could post your pic or add a link to your thread where you did the connector repair? Appreciated! Found it. The first repair I did (fabricating a new tab and soldering to the window silver) starts here. Later the silver the tabs were attached to came off the glass so I repaired using conductive epoxy which starts here. |
bob164 |
May 30 2022, 09:04 PM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Chris,
I will take it. I will arrange for Rich to pick it up. Check your PMs. Bob |
Lo-Fi Version | Time is now: 17th May 2024 - 03:14 PM |
