VEMS Fuel Injection for 3.2, Plug & play modern system. |
May 30 2022, 06:12 PM
VEMS fuel injection for 3.2 engine. Plug and play into the stock 3.2 motronic harness.
Kit includes: -VEMS ecu with Bluetooth -DME harness adaptor -Bosch LS4.2 WBO2 sensor -Air temp sensor + short adaptor cable to connect it to AFM plug. -TPS with 6 pin -> 3 pin short adaptor cable. I purchased this system from Peep (Raceboy on pelican). It replaces the stock ecu and air flow meter, is fully programmable and 100% reversible. Uses modern injectors. More info at - https://m.facebook.com/vemsporsche $1,250 Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:44 PM |
