VEMS fuel injection for 3.2 engine. Plug and play into the stock 3.2 motronic harness.
Kit includes:
-VEMS ecu with Bluetooth
-DME harness adaptor
-Bosch LS4.2 WBO2 sensor
-Air temp sensor + short adaptor cable to connect it to AFM plug.
-TPS with 6 pin -> 3 pin short adaptor cable.
I purchased this system from Peep (Raceboy on pelican). It replaces the stock ecu and air flow meter, is fully programmable and 100% reversible. Uses modern injectors. More info at - https://m.facebook.com/vemsporsche
$1,250
