Sold: Aluminum 911 Front Crossmember $250 |
bdstone914 |
Jun 11 2022, 07:01 PM
This is a 911 aluminum front suspension that has been sand blasted, wire wheel burnished and clear coated to prevent oxidation.it is a direct replacement for a steel cross member. You will need the two brackets that bolt to it and the body. They are available new from Porsche. Has a minor repair in the area of an adjuster screw. A small piece of aluminum was welded in.
Asking $250 Attached thumbnail(s) |
bdstone914 |
Jun 11 2022, 07:02 PM
Repaired area.
Montreal914 |
Jun 11 2022, 07:42 PM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Bruce, just to fully understand, this part could be used with a /4 suspension without any modifications?
Will the piece at the end of the /4 torsion bar fit in there or it requires the 911 torsion bar end, and therefore the 911 torsion bar and 911 a-arm? Thanks! (IMG:style_emoticons/default/beerchug.gif) |
Jun 11 2022, 08:40 PM
You need the two flat metal straps and the stock 914 metal belly pan will not fit.
914 torsion bar adjusters fit fine. |
Montreal914 |
Jun 12 2022, 05:40 PM
So a couple of these bracket, then good to go... (IMG:style_emoticons/default/idea.gif)
But the pan is a good thing to have though for protection of that area (IMG:style_emoticons/default/dry.gif). Need to think about it. |
Steve |
Jun 12 2022, 05:48 PM
914 Guru Group: Members Posts: 5,587 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The 911 belly plan bolts right up to it. Sierra Madre sells new ones. Used ones are usually pretty trashed. It doesn’t fit as flush as a 914 belly pan, but good enough. What I love about the aluminum cross member is it has the holes for a fuel pump.
DaveB |
Jun 13 2022, 01:09 AM
Member Group: Members Posts: 163 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
eMail sent.
DaveB |
2mAn |
Jun 13 2022, 11:02 PM
trying to see how long I can go without a 914 Group: Members Posts: 487 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
Is this just to save weight or...?...
DaveB |
Jun 14 2022, 12:40 AM
Is this just to save weight or...?... I purchased it. In theory the alloy should distribute the load from the torsion bar better than steel. I'd like to find out if this crossmember provides an improvement. If not, I'll tell folks it looks cool and saves weight. DaveB |
Lo-Fi Version | Time is now: 17th May 2024 - 05:11 PM |
