This is a 911 aluminum front suspension that has been sand blasted, wire wheel burnished and clear coated to prevent oxidation.it is a direct replacement for a steel cross member. You will need the two brackets that bolt to it and the body. They are available new from Porsche. Has a minor repair in the area of an adjuster screw. A small piece of aluminum was welded in.
Asking $250
