Slippin in a 6, Fuel pump ??? |
Markeydoo |
Aug 3 2005, 10:08 PM
??? Group: Members Posts: 246 Joined: 10-April 03 From: Socal Ventura Member No.: 557 Region Association: None |
Ok it's time for a change. I am installing a 6 with weber 40 carbs. I don't have the original fule pump so what is a good replacement? I know the pressure should be around 3.5 pounds but I dont know what else it needs like gallons per hour. I am also looking for the part number of the original pump.
Thanks Mark |
echocanyons |
Aug 3 2005, 10:13 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I hear a peirburg pump to a continuous loop circuit with a bypass regulator recirculating back to the tank is a good method
Joe Bob |
Aug 3 2005, 10:24 PM
Rotary pumps....Purolator, Holley etc...
Trekkor |
Aug 3 2005, 10:40 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I have been using the Holley Red low pressure pump and one-in-two-out pressure regulator since January with *zero* problems.
KT Attached image(s) |
Trekkor |
Aug 3 2005, 10:42 PM
Attached image(s) |
Markeydoo |
Aug 4 2005, 09:58 PM
Thanks Guys.
North Bay 914 |
Aug 4 2005, 10:50 PM
Senior Member Group: Members Posts: 509 Joined: 25-January 05 Member No.: 3,504 |
Did you get the Throttle cable yet?
Lo-Fi Version | Time is now: 16th May 2024 - 02:05 AM |
