Can a1.7l case be substituted by a 2.0l case? |
PCH |
Jun 16 2022, 09:50 AM
Member Group: Members Posts: 141 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
I have a 1.7l case that has a fatal problem. The engine build has 96x66mm pistons and cylinders and 1.8 liter heads.
Can I use a 2.0l case with the components that I currently have? Or do I have to stick with a 1.7l case? |
BeatNavy |
Jun 16 2022, 10:00 AM
All cases are basically the same. So to answer your question, yes, you can use those components.
What's your goal? You've got a 1911 with those P&C. |
PCH |
Jun 16 2022, 10:25 AM
Garold has a 2.0 l case for sale and I need a case to replace my troubled 1.7l case. I just want to be sure that it will work.
930cabman |
Jun 16 2022, 10:42 AM
Advanced Member Group: Members Posts: 3,088 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
According to Jake Raby, the 1.7 case has more material in the area of the journals than either 1.8 or 2.0. So long as everything is straight/round you should be good to go.
BeatNavy |
Jun 16 2022, 11:27 AM
According to Jake Raby, the 1.7 case has more material in the area of the journals than either 1.8 or 2.0. So long as everything is straight/round you should be good to go. He's going from 1.7 to 2.0 (in theory), so that's kind of going the other way. No offense to Garold, who's an asset to the community here and a great resource, but there are probably a lot of 1.7L cases available out there if you put out a WTB. What's most important is bore alignment and whether or not there's droop in the spigots, a function of "less meat" on the 2.0 case but also how much that case has been abused over the years. I'd probably prioritize case condition, type (1.7L vs. 2.0), and case number (just to have consistent with what's supposed to be in there) in that order. |
PCH |
Jun 16 2022, 03:42 PM
Thank you for your advice. I appreciate how quickly help is available on 914world!
Jun 16 2022, 04:09 PM
914-6 GT in waiting Group: Members Posts: 19,286 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Core 1.7’s are usually a dime a dozen. Ask around and you should be able to find one cheap. No reason to pay the premium for a 2.0 case when the early 1.7’s are arguably better.
Lo-Fi Version | Time is now: 24th May 2024 - 06:19 PM |
