Engine Tins With “Heat Riser”?, What do they fit? |
Tbrown4x4 |
Jun 21 2022, 05:47 PM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I have a set of engine tins that have a plastic tube attached to a square hole in the driver’s side rear. What years does this fit? The parts manual says WO engine if I read it correctly.
Attached image(s) |
914werke |
Jun 21 2022, 06:44 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
early 1.7 with oil bath air filter.
rhodyguy |
Jun 22 2022, 07:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Do a WTB for a later set of 1.8 upper tin. That set you have might be of some value to a person needing that specific style.
L-Jet914 |
Jun 25 2022, 07:26 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
As stated above the engine tin is for a 1.7 with a thermostatic air cleaner assembly. All for early emissions controls to help get the intake temperatures up quicker to allow for better fuel atomization. When the temperature reached a certain point usually a bi-metallic spring would shut off flow from that pipe and start pulling "fresh cooler air."
Tbrown4x4 |
Jul 1 2022, 11:58 PM
Thanks everyone. It must be the original stuff for my 71 parts car.
Garland |
Feb 27 2023, 01:14 PM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
“I have a set of engine tins that have a plastic tube attached to a square hole in the driver’s side rear. What years does this fit? The parts manual says WO engine if I read it correctly.“
That’s specific to 72-1.7 |
Lo-Fi Version | Time is now: 28th April 2024 - 02:54 PM |
