Trunk "pocket"? |
Trunk "pocket"? |
Archie |
Jun 23 2022, 06:14 PM
Member Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest |
dlee6204 |
Jun 23 2022, 06:19 PM
The theory I've heard is the inner structure was designed when there was going to be a fuel door in the hood and the "pocket" was to accommodate that. The fuel door was later axed in the design phase but the feature in the inner structure remained.
Robarabian |
Jun 23 2022, 06:50 PM
914 A Roo Group: Members Posts: 591 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
My hypothesis on the shift rod sleeve is... you would cut off the end after indexing its location for reattachment. Remove it. Press on a sleeve you believe is the right dimension. Weld on the end you cut off.
That being said, it looks like the powder coat layer is worn off.. maybe just have it re-powder coated to bring it back into spec? A micrometer would tell you... |
StarBear |
Jun 23 2022, 07:22 PM
Senior Member Group: Members Posts: 1,855 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
The theory I've heard is the inner structure was designed when there was going to be a fuel door in the hood and the "pocket" was to accommodate that. The fuel door was later axed in the design phase but the feature in the inner structure remained. Yep. A similar thread a few months ago. That’s the consensus. |
Jun 23 2022, 08:58 PM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The theory I've heard is the inner structure was designed when there was going to be a fuel door in the hood and the "pocket" was to accommodate that. The fuel door was later axed in the design phase but the feature in the inner structure remained. Yep. A similar thread a few months ago. That’s the consensus. Here is the 914.006 prototype with the fuel door that never made it to production: Attached thumbnail(s) |
StarBear |
Jun 24 2022, 06:27 AM
The theory I've heard is the inner structure was designed when there was going to be a fuel door in the hood and the "pocket" was to accommodate that. The fuel door was later axed in the design phase but the feature in the inner structure remained. Yep. A similar thread a few months ago. That’s the consensus. Here is the 914.006 prototype with the fuel door that never made it to production: NEAT! An archive keeper. |
Arno914 |
Jun 24 2022, 07:20 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
@Archie :
My shift rod looks the same. Powder coating worn off and maybe some metal, too. I wouldn´t worry too much, unless it is really out of round. Get someone with a lathe to machine a new Nylon bushing that fits snug. Job done. Some clearance seems to be necessary anyways. I replaced all bushings on my tailshifter with good-fit selfmade ones. Huge difference in shifting! No need to convert to side shifter. The bushing in the rear firewall is somewhat a pita to get in (cut grooves like a crown to be able to press it in). Well worth the effort. (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1656076830.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1656076831.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1656076832.3.jpg) |
dr914@autoatlanta.com |
Jun 24 2022, 09:55 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yup and yup
Archie |
Jun 24 2022, 09:06 PM
Many thanks to all for responding, and following on from the shifter rod topic, what is the consensus on the aftermarket bronze bushing replacements - like George sells - for the the OEM plastic thingies. Don't they contribute more wear to the shaft?
Archie |
Jul 7 2022, 09:05 PM
@Archie : My shift rod looks the same. Powder coating worn off and maybe some metal, too. I wouldn´t worry too much, unless it is really out of round. Get someone with a lathe to machine a new Nylon bushing that fits snug. Job done. Some clearance seems to be necessary anyways. I replaced all bushings on my tailshifter with good-fit selfmade ones. Huge difference in shifting! No need to convert to side shifter. The bushing in the rear firewall is somewhat a pita to get in (cut grooves like a crown to be able to press it in). Well worth the effort. (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1656076830.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1656076831.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1656076832.3.jpg) Great advice, Arno! Thank you! I shouldn't concern myself with the aftermarket bonze bushings, then? |
Jul 7 2022, 09:39 PM
Great advice, Arno! Thank you! I shouldn't concern myself with the aftermarket bonze bushings, then? As far as i know, there are no bronze bushings for the firewall. Only for the pedal cluster and the rear where the shift rod connects to the transmission console. All the firewall bushings i have seen were made of plastic. (IMG:style_emoticons/default/popcorn[1].gif) |
Mikey914 |
Jul 9 2022, 04:31 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Or just buy the bushing with the groves in it. My 72 shifts well and in my opinion gets a bad rap because many folks don’t replace the bushings. Do them all, and they will make a huge difference. The factory knew what they were doing.
https://914rubber.com/tail-shift-rod-bushin...-tunnel-for-914 Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:55 AM |
