Why my car has no front or rear sway bars?, Suspension upgrades or not |
Spoke |
Jun 28 2022, 10:09 AM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My '71 didn't have front or rear sway bars. So I knocked off 2 projects at once: 911 underbody sway bar and 5-lug conversion. No drilling or welding; bolt on.
gandalf_025 |
Jun 28 2022, 11:00 AM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
My factory 6 came without sway bars, but it did have the tabs on the A arms.
I bought a 19mm front bar from H+H Specialties in 1974, The owner of H+H lived 2 towns away from me and I drove to his house to get it. I went with the H+H because you could install it without removing the gas tank.. I have ABSOLUTELY no track experience, but what I noticed with the bar installed was A corner I could normally take at 70 mph before the bar, was fine with the front bar installed at 80 mph.... Then the back of the car started feeling a little loose. So I went back and bought the rear bar and that same corner could now be taken at 90 mph.. It really felt locked down and well planted.. What nobody explained to me at that point was.... You can OVER drive a set of sway bars and when that happens... It happens fast and you have absolutely no control.. You are just along for the ride.. I was 19 at the time and I survived.. Still have the car too.. I did manage to spin it a few times and was lucky to never hit anything.. |
Jun 28 2022, 11:35 AM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My factory 6 came without sway bars, but it did have the tabs on the A arms. I bought a 19mm front bar from H+H Specialties in 1974, The owner of H+H lived 2 towns away from me and I drove to his house to get it. I went with the H+H because you could install it without removing the gas tank.. I have ABSOLUTELY no track experience, but what I noticed with the bar installed was A corner I could normally take at 70 mph before the bar, was fine with the front bar installed at 80 mph.... Then the back of the car started feeling a little loose. So I went back and bought the rear bar and that same corner could now be taken at 90 mph.. It really felt locked down and well planted.. What nobody explained to me at that point was.... You can OVER drive a set of sway bars and when that happens... It happens fast and you have absolutely no control.. You are just along for the ride.. I was 19 at the time and I survived.. Still have the car too.. I did manage to spin it a few times and was lucky to never hit anything.. My friend had a GT3 and he said the limit was so high, he knew when it let go, he’d be in a lot of trouble. |
CCE |
Jun 28 2022, 12:14 PM
CCE Group: Members Posts: 320 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
My 72' was the same way. I put them front and rear and wow what a difference. Tabs: https://www.elephantracing.com/911/swaybars...bars/u-tab-kit/ I have a quotation from elephant racing, it’s just too much for the moment, I know I will do eventually. Just need to be sure of all the options. 914world is helping a lot. (IMG:style_emoticons/default/driving.gif) |
CCE |
Jun 28 2022, 12:15 PM
CCE |
Jun 28 2022, 12:24 PM
My factory 6 came without sway bars, but it did have the tabs on the A arms. I bought a 19mm front bar from H+H Specialties in 1974, The owner of H+H lived 2 towns away from me and I drove to his house to get it. I went with the H+H because you could install it without removing the gas tank.. I have ABSOLUTELY no track experience, but what I noticed with the bar installed was A corner I could normally take at 70 mph before the bar, was fine with the front bar installed at 80 mph.... Then the back of the car started feeling a little loose. So I went back and bought the rear bar and that same corner could now be taken at 90 mph.. It really felt locked down and well planted.. What nobody explained to me at that point was.... You can OVER drive a set of sway bars and when that happens... It happens fast and you have absolutely no control.. You are just along for the ride.. I was 19 at the time and I survived.. Still have the car too.. I did manage to spin it a few times and was lucky to never hit anything.. I think “that” is the mid engine configuration for you, I am used to drive VW beetles here (had 4 in a row, from 92, to 2004) love them, I had one tuned with bars and Bilstein it was hard on the back as a rock, it was hilarious, but oversteer was a daily thing, and 360 turns in the rain was also a thing, (till my brother took it for a ride) you get used to it. Now with the 914 It’s very similar only 400,000 times better. I am loving the process (IMG:style_emoticons/default/irish914.jpg) |
brant |
Jun 28 2022, 12:32 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
look for used.
also check the pelican parts forums the 911 (through the body bar) is the same as the 914 steer clear of the 911 underbody sway bar, as it will require different mounting tabs and is generally used when doing a full 911 suspension swap the through the body bar (early 911, and 914) gives better geometry anyways. |
ndfrigi |
Jun 28 2022, 12:41 PM
Advanced Member Group: Members Posts: 2,929 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
My 72' was the same way. I put them front and rear and wow what a difference. Tabs: https://www.elephantracing.com/911/swaybars...bars/u-tab-kit/ I have a quotation from elephant racing, it’s just too much for the moment, I know I will do eventually. Just need to be sure of all the options. 914world is helping a lot. (IMG:style_emoticons/default/driving.gif) Try to change the front shock/insert for now and check if you will be okay with that for the meantime or even the rear shocks may also make a big difference from that old shocks/inserts. |
My 72' was the same way. I put them front and rear and wow what a difference. Tabs: https://www.elephantracing.com/911/swaybars...bars/u-tab-kit/ I have a quotation from elephant racing, it’s just too much for the moment, I know I will do eventually. Just need to be sure of all the options. 914world is helping a lot. (IMG:style_emoticons/default/driving.gif) Most of the elephant racing sway bars are pretty big and heavy duty. It may not be what you want for a road car. You should be able to get a stock 914 front bar for about $200-400. It will probably be the most bang for your buck. Then add a rear bar as money permits. |
Shivers |
Jun 28 2022, 12:47 PM
Senior Member Group: Members Posts: 2,390 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
My 72' was the same way. I put them front and rear and wow what a difference. Tabs: https://www.elephantracing.com/911/swaybars...bars/u-tab-kit/ I have a quotation from elephant racing, it’s just too much for the moment, I know I will do eventually. Just need to be sure of all the options. 914world is helping a lot. (IMG:style_emoticons/default/driving.gif) Well I can not afford anything from elephant unless I get a deal on it. If you want I'll pull a tape on mine, I know I could make my own if I needed to. |
autopro |
Jun 28 2022, 12:56 PM
Member Group: Members Posts: 306 Joined: 14-January 18 From: San Diego / Tijuana Member No.: 21,797 Region Association: Southern California |
Brian Fuerbach |
Jun 28 2022, 01:49 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
914Next |
Jun 28 2022, 02:03 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Wait…..a Mexico barn find? In storage 40 years? Did I miss this story? I gotta know more! And w are you located in Mexico.
Steve |
CCE |
Jun 28 2022, 02:10 PM
Wait…..a Mexico barn find? In storage 40 years? Did I miss this story? I gotta know more! And w are you located in Mexico. Steve That is correct. In Mexico city, it was last moved around 1981 after imported from LA/USA, I knew the car in 1985 more or less, but I was not allowed near the car, NEVER… the owner passed away 5 years ago, my friend called me to ask if I was interested last November… So, next thing… |
914Next |
Jun 28 2022, 02:13 PM
[quote name='CCE' date='Jun 28 2022, 04:10 PM' post='3011851']
[quote name='914Next' post='3011850' date='Jun 28 2022, 03:03 PM'] Wait…..a Mexico barn find? In storage 40 years? Did I miss this story? I gotta know more! And w are you located in Mexico. Steve [/quote] That is correct. In Mexico city, I knew the car in 1985 more or less, but I was not allowed near the car, NEVER… the owner passed away 5 years ago, my friend called me to ask if I was interested last November… So next thing… [/quote Nice. Would love to see more pics and hear more about the story.. What is the condition? I’m from the states but live near Guadalajara now. |
CCE |
Jun 28 2022, 02:29 PM
[quote name='914Next' date='Jun 28 2022, 03:13 PM' post='3011853']
[quote name='CCE' date='Jun 28 2022, 04:10 PM' post='3011851'] [quote name='914Next' post='3011850' date='Jun 28 2022, 03:03 PM'] Wait…..a Mexico barn find? In storage 40 years? Did I miss this story? I gotta know more! And w are you located in Mexico. Steve [/quote] That is correct. In Mexico city, I knew the car in 1985 more or less, but I was not allowed near the car, NEVER… the owner passed away 5 years ago, my friend called me to ask if I was interested last November… So next thing… [/quote Nice. Would love to see more pics and hear more about the story.. What is the condition? I’m from the states but live near Guadalajara now. [/quote] I have a vey rustic video on you tube you may like. https://youtu.be/uow_y-61hxc https://youtu.be/0TKeQhttLHQ |
ndfrigi |
I think the owner also posted a video on youtube. If yes, hope the owner can share the youtube link here.
CCE |
Jun 28 2022, 02:41 PM
I think the owner also posted a video on youtube. If yes, hope the owner can share the youtube link here. https://youtu.be/uow_y-61hxc https://youtu.be/0TKeQhttLHQ https://youtu.be/fouqlBMV-sk https://youtu.be/lTHjHWGmVYk Here you go… |
CCE |
Jun 29 2022, 12:09 PM
My 72' was the same way. I put them front and rear and wow what a difference. Tabs: https://www.elephantracing.com/911/swaybars...bars/u-tab-kit/ I have a quotation from elephant racing, it’s just too much for the moment, I know I will do eventually. Just need to be sure of all the options. 914world is helping a lot. (IMG:style_emoticons/default/driving.gif) Try to change the front shock/insert for now and check if you will be okay with that for the meantime or even the rear shocks may also make a big difference from that old shocks/inserts. I got the shocks yesterday, I will install right away. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:39 PM |
