Todays Gauge Build, GT Style NOT Replica |
914Sixer |
Jun 27 2022, 06:45 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All you need is some one to do your dial face. You will need two different gauges and a soldering gun. If you have a cleaned everything up, should take 10 minutes to build gauge with parts ready to go. This a 60mm gauge so you can use it in the console. NOTE the red low light is in the left position like stock gauge NOT at 1 o"clock like GT
914werke |
Jun 27 2022, 07:54 PM
"I got blisters on me fingers" Group: Members Posts: 10,029 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Nice!
Montreal914 |
Jun 27 2022, 09:20 PM
Senior Member Group: Members Posts: 1,543 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Nice teaser! (IMG:style_emoticons/default/smile.gif)
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Justinp71 |
Jun 28 2022, 03:30 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
All you need is some one to do your dial face. You will need two different gauges and a soldering gun. If you have a cleaned everything up, should take 10 minutes to build gauge with parts ready to go. This a 60mm gauge so you can use it in the console. NOTE the red low light is in the left position like stock gauge NOT at 1 o"clock like GT Do you have the part number on that fuel gauge? I have one but it reads a little on the low side. So if I truly have half a tank it will show about a 1/4 tank or less. |
Root_Werks |
Jun 29 2022, 12:08 PM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Curiuos what gauge you are using. I opted for the 2 1/16 VDO in the lower dash:
http://www.914world.com/bbs2/index.php?sho...=346657&hl= The correct-est gauge is NLA VDO 301-220. I found a NOS unit = luck. I've run the tank full and with only 1.5 gallons. The VDO 301-220 is very close to spot on with the 914 sending unit. |
914Sixer |
Jun 29 2022, 01:11 PM
Gauge is custom built using 911 fuel gauge and 67 Saab fuel gauge. 911 unit and the 914 have the same resistance. Using the 60mm Saab gauge you get the console size hole and low fuel light bulb holder. You unsolder the Saab unit and solder in the 911 unit. Had face done to the style of the 914 console gauge.
Yes VDO 301-220 is the closest gauge to 914 fuel tank. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st May 2024 - 09:46 AM |
