Console Gauge Wiring Harness, Is It Somewhat Plug & Play? |
Rick986 |
Jun 28 2022, 07:38 AM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
My '75 914 came with a center console that appears to be an add-on based on how it's wired. As well, the color of the wires don't match the diagrams I've found.
P.O. also installed an aftermarket radio that has power wires tied into the gauge wires. I've got some intermittent gremlins that need addressed and I want to clean this up/make it right. I see that AA and others sell a console gauge harness and believe I have read that '73+ cars came with the wiring necessary to connect this to. Is this correct? I haven't taken out the whole console yet to see where the current spaghetti setup is going...and not crazy about getting this deep if it's not going to fix the problems. Thanks guys! |
914werke |
Jun 28 2022, 08:55 AM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have read that '73+ cars came with the wiring necessary to connect this to. Is this correct? It is. You car should have 3 connectors approx. parallel with your heater lever in a relief atop of the tunnel where the main harness runs. This is the OE spot which the console harness attaches. |
dr914@autoatlanta.com |
Jun 28 2022, 09:01 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
It is very easy to wire and the pigtail is built into the 75 wiring harness. Jeff B makes a perfect new console wiring harness that we sell
My '75 914 came with a center console that appears to be an add-on based on how it's wired. As well, the color of the wires don't match the diagrams I've found. P.O. also installed an aftermarket radio that has power wires tied into the gauge wires. I've got some intermittent gremlins that need addressed and I want to clean this up/make it right. I see that AA and others sell a console gauge harness and believe I have read that '73+ cars came with the wiring necessary to connect this to. Is this correct? I haven't taken out the whole console yet to see where the current spaghetti setup is going...and not crazy about getting this deep if it's not going to fix the problems. Thanks guys! |
Rick986 |
Jun 28 2022, 09:34 AM
Thanks George. I'm going to take the console out and see what I'm working with.
It is very easy to wire and the pigtail is built into the 75 wiring harness. Jeff B makes a perfect new console wiring harness that we sell My '75 914 came with a center console that appears to be an add-on based on how it's wired. As well, the color of the wires don't match the diagrams I've found. P.O. also installed an aftermarket radio that has power wires tied into the gauge wires. I've got some intermittent gremlins that need addressed and I want to clean this up/make it right. I see that AA and others sell a console gauge harness and believe I have read that '73+ cars came with the wiring necessary to connect this to. Is this correct? I haven't taken out the whole console yet to see where the current spaghetti setup is going...and not crazy about getting this deep if it's not going to fix the problems. Thanks guys! |
Lo-Fi Version | Time is now: 28th April 2024 - 11:12 PM |
