Polishing Fuch's, the easy way |
76-914 |
Jul 5 2022, 03:15 PM
Yesterday I set out to polish the Fuch's on my '73 which is fairly easy since they are fully polished and I do them once a year. I had been putting off polishing the Fuch's on my '76 because only the raised petals are polished and I had convinced myself this would be a miserable job. But since I'm in fixing her up to sell I knew they would need to be done at some point and the weather was cool enough for the toil to come. They hadn't been touched in 10+ years and didn't look too badly from a distance.
But up close........not so nice. As it turned out I needed only to mask off the outer rim where the polished edge meets the unpolished edge. Some cheap HF electrical take was perfect for the job. This is about 5 minutes work using Mothers polish and this little 2" DA. Another minute to wipe off with a clean cotton cloth. Very little blackened residue gets on the unpolished surface. And what little does can be quickly cleaned up with some LA Awesome cleaner. I suppose Simple Green would work also. Finished product.......about 30 minutes total time. There are 2 more but they all look the same and I think this hard drive is about to die! Attached image(s) |
rhodyguy |
Jul 5 2022, 03:37 PM
Nice Kent.
914-300Hemi |
Jul 5 2022, 03:51 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
very nice
Jul 5 2022, 04:05 PM
Wow, inspiring.
DC_neun_vierzehn |
Jul 5 2022, 08:00 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Great work.
If you wanted to really make them wheels sparkle, for less than $100 (I believe) you could get new aftermarket Fuchs lugs from 914 Rubber. You could probably sell the original lugs for the same amount to someone who wants the original lugs (which could be re-plated I believe). |
76-914 |
Jul 5 2022, 08:04 PM
Great work. If you wanted to really make them wheels sparkle, for less than $100 (I believe) you could get new aftermarket Fuchs lugs from 914 Rubber. You could probably sell the original lugs for the same amount to someone who wants the original lugs (which could be re-plated I believe). Aren't those new bolts 17mm vs. the 19mm OEM? |
bdstone914 |
Jul 5 2022, 08:09 PM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Great work. If you wanted to really make them wheels sparkle, for less than $100 (I believe) you could get new aftermarket Fuchs lugs from 914 Rubber. You could probably sell the original lugs for the same amount to someone who wants the original lugs (which could be re-plated I believe). Aren't those new bolts 17mm vs. the 19mm OEM? Yes and chrome i believe. I have replated several sets in clear zinc. |
Spoke |
Jul 5 2022, 09:38 PM
Sweet. Love to see the 'elbow grease' polish jobs. The wheels look great.
Blue6 |
Jul 5 2022, 09:46 PM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Nice workKent, they look great
DC_neun_vierzehn |
Jul 5 2022, 09:55 PM
Great work. If you wanted to really make them wheels sparkle, for less than $100 (I believe) you could get new aftermarket Fuchs lugs from 914 Rubber. You could probably sell the original lugs for the same amount to someone who wants the original lugs (which could be re-plated I believe). Aren't those new bolts 17mm vs. the 19mm OEM? Yes and chrome i believe. I have replated several sets in clear zinc. I saw that somebody had new aftermarket 19mm lugs for Fuchs … guess it wasn’t 914 Rubber. |
914Sixer |
Jul 7 2022, 06:19 AM
Go on Ebay, You need M14x1.5 Ball Seat 40mm long. Yes they a have 17mm heads NOT 19mm. You can even get them in black.
Attached thumbnail(s) |
StarBear |
Jul 7 2022, 08:31 AM
Senior Member Group: Members Posts: 1,884 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
tygaboy |
Jul 7 2022, 09:48 AM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Wheels look SOOOOOO much better! Nice.
76-914 |
Jul 10 2022, 05:22 PM
Since @DC_neun_vierzehn shamed me (IMG:style_emoticons/default/lol-2.gif) I decided to paint the lug nuts to match the unpolished petals until I can find a reputable plater that isn't backed up. Ogden Plating said 6-8 months. Wish someone could put together a "lug nut re-chrome" group buy. @ValcoOscar (IMG:style_emoticons/default/sad.gif)
DC_neun_vierzehn |
Jul 19 2022, 02:48 PM
Since @DC_neun_vierzehn shamed me (IMG:style_emoticons/default/lol-2.gif) I decided to paint the lug nuts to match the unpolished petals until I can find a reputable plater that isn't backed up. Ogden Plating said 6-8 months. Wish someone could put together a "lug nut re-chrome" group buy. @ValcoOscar (IMG:style_emoticons/default/sad.gif) Haha. Those lugs look great! |
Lo-Fi Version | Time is now: 16th May 2024 - 01:22 AM |
