WTB: Concave washers for CV joint |
narino |
Jul 9 2022, 01:30 AM
Member Group: Members Posts: 231 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None |
Looking for 3 of these concave washers. #22 in the image below.
Thank you! (IMG:http://www.914world.com/bbs2/uploads/post-8001-1657322944.jpg) |
bdstone914 |
Jul 9 2022, 08:18 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Looking for 3 of these concave washers. #22 in the image below. Thank you! (IMG:http://www.914world.com/bbs2/uploads/post-8001-1657322944.jpg) They are available new from VW or Porsche. Call a dealer and give them the part number. |
narino |
Jul 9 2022, 12:05 PM
They are available new from VW or Porsche. Call a dealer and give them the part number. Thanks Bruce, just called the downtown VW parts department they said the parts # isn't correct for the concave washer, it's coming up as the schnorr washer on VW catalogue. I was using part number 113501327. If I pull up a parts catalogue on VW bug same year is the assembly the same? Thank you! (IMG:style_emoticons/default/beer.gif) Edit* the parts guy said his listing showed it had teeth. I think this is what he was seeing. VW CV washer . This won't work, correct? |
bdstone914 |
Jul 9 2022, 12:18 PM
They are available new from VW or Porsche. Call a dealer and give them the part number. Thanks Bruce, just called the downtown VW parts department they said the parts # isn't correct for the concave washer, it's coming up as the schnorr washer on VW catalogue. I was using part number 113501327. If I pull up a parts catalogue on VW bug same year is the assembly the same? Thank you! (IMG:style_emoticons/default/beer.gif) It is a Belleville washer and a Schnoor washer is a brand of Bellevelle washer. That is the correct part number and it is also used on VWs. I dont really see the purpose of them and have not been able to get them installed with the CV. |
IronHillRestorations |
Jul 11 2022, 05:36 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
They are available new from VW or Porsche. Call a dealer and give them the part number. Thanks Bruce, just called the downtown VW parts department they said the parts # isn't correct for the concave washer, it's coming up as the schnorr washer on VW catalogue. I was using part number 113501327. If I pull up a parts catalogue on VW bug same year is the assembly the same? Thank you! (IMG:style_emoticons/default/beer.gif) It is a Belleville washer and a Schnoor washer is a brand of Bellevelle washer. That is the correct part number and it is also used on VWs. I dont really see the purpose of them and have not been able to get them installed with the CV. It requires a press, that’s the only way I’ve been able to install them. |
rhodyguy |
Jul 11 2022, 11:55 AM
McMaster Carr.
914e |
Jul 11 2022, 05:46 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
113-501-327 - Seems to be the Porsche version. 113-501-327A - Seems to be a VW variant with cuts for the splines. I have no idea if it would work. The Audi part for that part number seems to be completely wrong. I can find them online in the $3-5 each range. I think it took two us to get them on, one pressing down as the other put on the snap ring. It seems to be there just to preload the CV joint against he snap ring.
Puebloswatcop |
Jul 11 2022, 07:33 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
PorscheAtlantaPerimiterParts.com has them for $3.15. If you cannot access them, let me know, I might have some hanging around.
Lo-Fi Version | Time is now: 14th May 2024 - 07:51 PM |
