CHT, On a 3.2 |
CHT, On a 3.2 |
NARP74 |
Jul 17 2022, 12:21 PM
Senior Member Group: Members Posts: 1,059 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
SirAndy |
Jul 17 2022, 12:54 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Dave_Darling |
Jul 17 2022, 03:42 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That looks to be a ring thermocouple which would be used for a gauge. They are made to go under spark plugs, generally.
It should not have anything to do with the FI; you don't really need it. --DD |
emerygt350 |
Jul 18 2022, 05:42 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
It looks like it is in poor shape too. I wouldnt reuse it even if you put it where it belongs (around a spark plug). A cht gauge is a fantastic thing to have, but I wouldnt trust that one's readings.
Luke M |
Jul 18 2022, 07:24 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
My guess is this is not factory. Where should it be on a 3.2? On a 3.2 the cht sensor screws into the side of the #3 cylinder head. Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head. |
emerygt350 |
Jul 18 2022, 08:35 AM
My guess is this is not factory. Where should it be on a 3.2? On a 3.2 the cht sensor screws into the side of the #3 cylinder head. Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head. I think we are looking at an aftermarket cht sender, not a part of the injection system. |
NARP74 |
Jul 18 2022, 09:02 AM
It's in a 914, I am guessing it is just for the gauge. I can't imagine that working for the FI. It is not a sensor or sender. I need to follow it back to see where it goes.
emerygt350 |
Jul 18 2022, 09:57 AM
It's in a 914, I am guessing it is just for the gauge. I can't imagine that working for the FI. It is not a sensor or sender. I need to follow it back to see where it goes. The sender for gauge chts are exactly like that. Just a ring of metal on a wire. A special ring, and a special wire. |
Luke M |
Jul 18 2022, 11:51 AM
My guess is this is not factory. Where should it be on a 3.2? On a 3.2 the cht sensor screws into the side of the #3 cylinder head. Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head. I think we are looking at an aftermarket cht sender, not a part of the injection system. I was answering the question on the location. What the op has posted is not a factory 3.2 cht sensor nor right location. The 3.2 org cht sensor is screwed into the side of the #3 cyl head and can be accessed through the rear engine sheet metal. What is pictured could be aftermarket unit that is supposed to go under a spark plug. Check the #3 head and you'll see a section that is milled off and has a hole with threads. |
emerygt350 |
Jul 18 2022, 06:37 PM
Yes, but are you describing the location of the cht that the ecu uses or the cht a gauge would use. That there, is something a gauge would use.
Lo-Fi Version | Time is now: 6th May 2024 - 11:23 AM |
