CHT, On a 3.2 |
CHT, On a 3.2 |
NARP74 |
Jul 17 2022, 12:21 PM
Senior Member Group: Members Posts: 1,067 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Luke M |
Jul 18 2022, 07:24 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
My guess is this is not factory. Where should it be on a 3.2? On a 3.2 the cht sensor screws into the side of the #3 cylinder head. Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head. |
emerygt350 |
Jul 18 2022, 08:35 AM
Advanced Member Group: Members Posts: 2,099 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
My guess is this is not factory. Where should it be on a 3.2? On a 3.2 the cht sensor screws into the side of the #3 cylinder head. Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head. I think we are looking at an aftermarket cht sender, not a part of the injection system. |
Luke M |
Jul 18 2022, 11:51 AM
My guess is this is not factory. Where should it be on a 3.2? On a 3.2 the cht sensor screws into the side of the #3 cylinder head. Look at the sheet metal covering that rear section you should see the wire hanging through it. That is if its in a 911 and factory motronic. If not it could be covered up with the engine sheet metal . Either way look at the #3 head. I think we are looking at an aftermarket cht sender, not a part of the injection system. I was answering the question on the location. What the op has posted is not a factory 3.2 cht sensor nor right location. The 3.2 org cht sensor is screwed into the side of the #3 cyl head and can be accessed through the rear engine sheet metal. What is pictured could be aftermarket unit that is supposed to go under a spark plug. Check the #3 head and you'll see a section that is milled off and has a hole with threads. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:43 AM |
