fuel cells, advice needed |
shadygrady |
Aug 4 2005, 10:08 PM
Member Group: Members Posts: 236 Joined: 10-July 05 From: Cumming, GA Member No.: 4,400 Region Association: South East States |
I want to put replace my stock gas tank in my 74 914-4 with a fuel cell in front well. any suggestions for brand and size as well as tips? I am swapping the 2.0 for a 1983 3.0. thanks
VegasRacer |
Aug 4 2005, 10:33 PM
ELVIRA Group: Benefactors Posts: 8,496 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
My top choice would be one of these from Patrick Motorsports. It fits right in the stock location. Not cheap, but a very clean install. If you don't want to spend the big bucks for this unit, be sure to get a good one from ATL or Fuel Safe. You want to mount it as low as possible. How big depends on how far apart the gas stations are on your longest trip.
Do you have an oil cooler in the front trunk? If so, it's size and location will be a factor in your choice of fuel cells. Attached image(s) |
smg914 |
Aug 5 2005, 08:02 AM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
I agree with vegasracer on the Patrick Motorsports cell as the first choice. However, if you go to a front trunk mounted fuel cell I highly recommend you get one that has a gravity fed fuel line on the bottom of the tank. Fuel pumps don't seem to like sucking fuel. They would prefer to have the fuel fed to it. I had fuel starvation problems in my fuel injected 914-4 race car and my weber carbed 914-6 race car and both problems were related to this issue.
Lo-Fi Version | Time is now: 2nd May 2024 - 06:23 AM |
