high idle, 3000rpm idle |
slotty008 |
Jul 24 2022, 03:29 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
Hi guys ,
I just hope that someone could help us with the idle of my '75 2.0. I have the car for almost 7 years now and idle was always a little bit too high. We have been trying to correct this but it got worse instead of better. We changed the distributor to a 123 ignition, we changed all the vacuumlines, the AAR has been cleaned out and the idle screw is completely closed. The car starts at 1600rpm when cold and once it is warm it goes to 3000rpm and the idle stays there. The car pulls very well , a lot better better than when I just had it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
brant |
Jul 29 2022, 05:23 PM
914 Wizard Group: Members Posts: 11,614 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Sounds like he suspects the bushings holding the butterfly/shaft in your throttle body are worn.
Easy enough to check And most of the throttle bodies are worn out on these djet cars by now |
Lo-Fi Version | Time is now: 26th April 2024 - 05:27 PM |
