high idle, 3000rpm idle |
slotty008 |
Jul 24 2022, 03:29 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
Hi guys ,
I just hope that someone could help us with the idle of my '75 2.0. I have the car for almost 7 years now and idle was always a little bit too high. We have been trying to correct this but it got worse instead of better. We changed the distributor to a 123 ignition, we changed all the vacuumlines, the AAR has been cleaned out and the idle screw is completely closed. The car starts at 1600rpm when cold and once it is warm it goes to 3000rpm and the idle stays there. The car pulls very well , a lot better better than when I just had it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
slotty008 |
Aug 9 2022, 12:57 PM
Update: I ordered a throttle body gasket and the rubber to the airfilter. My mechanic installed them today but the problem is not gone. (IMG:style_emoticons/default/headbang.gif) He thinks that the throttle valve is worn( axle and bushings) I suppose throttle bodies are no longer available so is it possible to repair this? (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 26th April 2024 - 07:17 PM |
