high idle, 3000rpm idle |
slotty008 |
Jul 24 2022, 03:29 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
Hi guys ,
I just hope that someone could help us with the idle of my '75 2.0. I have the car for almost 7 years now and idle was always a little bit too high. We have been trying to correct this but it got worse instead of better. We changed the distributor to a 123 ignition, we changed all the vacuumlines, the AAR has been cleaned out and the idle screw is completely closed. The car starts at 1600rpm when cold and once it is warm it goes to 3000rpm and the idle stays there. The car pulls very well , a lot better better than when I just had it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
slotty008 |
Mar 24 2024, 09:23 AM
After disassembling the AAR several times, I gave up. Once installed , everything went fine until the next day and then it jammed again. So I constructed a system with a solenoid valve instead of the AAR that I can open or close from the cockpit. I open it when I start the car and after two minutes I close and I have a 1000rpm idle. It's not perfect because it's all or nothing but certainly better than an unreliable AAR.
Lo-Fi Version | Time is now: 28th April 2024 - 07:51 AM |
