Project 914n6 -> the infamous Nissan V6 swap, new motor buildup |
Chris914n6 |
Jul 26 2022, 03:04 AM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Logic, according to my brain...
In 2000 I installed a Nissan VQ30, 3.0L from a 97 Maxima. 190hp 205tq and it was great. Then things happened (rusted battery tray). Then it sat for a decade (recession). The engine now overheats the cooling system like a bad head gasket. Likely from aluminum erosion from sitting too long (other signs). Fixing that requires complete disassembly down to a short block. Soooo.... I decided to move up to a VQ35, 03 Maxima 3.5L +80hp!!! (that's 42% more) Here's the rub. To get the VQ30 to fit I moved everything forward 1.5". Renegade sbc trans blocks, shortened shift rod, small hole in the truck. To fit the VQ35 as-is I would need to move it back, likely to stock location, to clear the variable cam timing stuff. That means a new cross mount, new shift rod, redo exhaust, plus new harness and ms3pro ecu ($$$$). Turns out the gearheads at Maxima.org like to upgrade too. They created a VQ30/35 hybrid. It's a VQ35 engine with VQ30 ecu, harness, timing components and accessories. I lose the variable cam timing but I get to reuse all my custom swap bits, which saves a bunch of time I don't have before RRC22. But it requires some new custom parts. If one or more of our great fabricators has time and tools I'd love to First is the Throttle Body adapter. Replacing the factory e-gas with cable. I currenly have this partially drawn in CorelDraw and design is not absolute (still searching hardware). 96mm x 99mm. TB (red) bolts to piece_1 (blue) which bolts to piece_2 (green) which bolts to IM (yellow). (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826257.1.jpg) Second is cam gear adapters/spacers in steel. I need 2 @ 178* and 2 @ 180*. 4 total cuz 4 cams of fury. 6mm dowel pins look to be readily available. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.2.jpg) Third is a pair of aluminum block-off plates for the VVT cam adjusters. 1.5" x 3.5" Also drawn in CorelDraw, which can be exported as .ai or .dxf. Actually I might make these by hand. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.3.jpg) Gratuitous PartsFinder pic (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.4.jpg) |
Chris914n6 |
Dec 3 2022, 01:10 AM
After RRC I wasn't in a hurry anymore... and I discovered Link now makes a plug-in 350z ecu... so I started rethinking the plan. (IMG:style_emoticons/default/idea.gif) I have a vq35de harness hidden somewhere. Nissan makes a floor mounted e-gas pedal. The 3.0L ecu will run the 3.5L but things will be a bit off so a new ecu was on the list anyways.
Plan the work. Work the plan. Change the plan. Spend more money. (IMG:style_emoticons/default/dry.gif) But luckily for my wallet I was motivated to work on something else. Plus it gets cold in my north facing garage. The infamous 1988 Nissan Partsfinder is pretty much worn out @233k. It's fine for local needs but sucks for touring and can barely get it's own butt up the Baker grade - forget towing a 914. I was looking into a newer Pathfinder (one with the vq35de (IMG:style_emoticons/default/biggrin.gif) ) when circumstances offered a likely better option. The next door neighbor's 2004 Chevy Blazer broke again and he was ready to move on. He took good care of it and I did most of the previous fixes, so I couldn't say no. BUT, what I thought was a bad spark plug wire and broken motor mount was actually a leaking injector and hydrolock damage (IMG:style_emoticons/default/sad.gif) So it sat for a while, because, frankly, Partsfinders don't break. (IMG:style_emoticons/default/aktion035.gif) Eventually I scored a 61k engine & trans from a wrecked 2001 S10. Last winter I finally committed to fixing it. I got it put together and running again by this summer but there were some other issues. After the 16 hours of driving for RRC I was motivated to finish the Blazer. Still a few little things but at this point it's practically (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1670051447.1.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:56 PM |
