Project 914n6 -> the infamous Nissan V6 swap, new motor buildup |
Chris914n6 |
Jul 26 2022, 03:04 AM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Logic, according to my brain...
In 2000 I installed a Nissan VQ30, 3.0L from a 97 Maxima. 190hp 205tq and it was great. Then things happened (rusted battery tray). Then it sat for a decade (recession). The engine now overheats the cooling system like a bad head gasket. Likely from aluminum erosion from sitting too long (other signs). Fixing that requires complete disassembly down to a short block. Soooo.... I decided to move up to a VQ35, 03 Maxima 3.5L +80hp!!! (that's 42% more) Here's the rub. To get the VQ30 to fit I moved everything forward 1.5". Renegade sbc trans blocks, shortened shift rod, small hole in the truck. To fit the VQ35 as-is I would need to move it back, likely to stock location, to clear the variable cam timing stuff. That means a new cross mount, new shift rod, redo exhaust, plus new harness and ms3pro ecu ($$$$). Turns out the gearheads at Maxima.org like to upgrade too. They created a VQ30/35 hybrid. It's a VQ35 engine with VQ30 ecu, harness, timing components and accessories. I lose the variable cam timing but I get to reuse all my custom swap bits, which saves a bunch of time I don't have before RRC22. But it requires some new custom parts. If one or more of our great fabricators has time and tools I'd love to First is the Throttle Body adapter. Replacing the factory e-gas with cable. I currenly have this partially drawn in CorelDraw and design is not absolute (still searching hardware). 96mm x 99mm. TB (red) bolts to piece_1 (blue) which bolts to piece_2 (green) which bolts to IM (yellow). (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826257.1.jpg) Second is cam gear adapters/spacers in steel. I need 2 @ 178* and 2 @ 180*. 4 total cuz 4 cams of fury. 6mm dowel pins look to be readily available. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.2.jpg) Third is a pair of aluminum block-off plates for the VVT cam adjusters. 1.5" x 3.5" Also drawn in CorelDraw, which can be exported as .ai or .dxf. Actually I might make these by hand. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.3.jpg) Gratuitous PartsFinder pic (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.4.jpg) |
ClayPerrine |
Apr 10 2023, 06:36 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I want to ask a curiosity question here.
Why use a WRX transmission? With it you have to remove all the stuff that hooks to the rear driveshaft, and install an aftermarket block off plate. Then you have to make custom axles to use it in a 914 chassis. And you still have to make an adapter plate/clutch assembly to hook it to the Nissan engine. Plus you have to fabricate a cable shift setup. Why not use a Boxster/Cayman G86-21 transmission? It is 2 wheel drive, so you don't have to do any mods to it, and you can use stock, unmodified Porsche 996 axles in a 914. And it already comes setup for a mid engine cable shifter. It also appears that the VQ35 starter mounts from the engine side (I could be wrong though), so with the Boxster/Cayman trans, you don't have a big unused open hole in the bell housing. The prices on the Porsche G86-21 trans are about $2500.00. The Subaru trans is cheaper, but with all the mods you have to do it may be cheaper to use the Porsche trans. Just my $.02 worth on it. |
Chris914n6 |
Apr 10 2023, 12:09 PM
I want to ask a curiosity question here. Why use a WRX transmission? Why not use a Boxster/Cayman G86-21 transmission? My engine is the FWD version as it's more plentiful and much cheaper. The RWD 350z/G35/etc tend to get thrashed. FWD has the starter on the trans, no provision on the engine side. Box6 disadvantages: making a starter fit 175 lbs short gearing have to buy or make flywheel small dia bellhousing Not going to cost $100 Suby advantages: bolt on starter 100 lbs plenty of conversions to work from decent gearing coupler & axles & plate $300-500 Here is the kicker... Suby flywheel bolts on with a spacer which allows me to use all stock parts. I can make the adapter. Only cost $100 (IMG:style_emoticons/default/piratenanner.gif) It's really a no brainer on my end. |
ClayPerrine |
Apr 10 2023, 12:39 PM
I want to ask a curiosity question here. Why use a WRX transmission? Why not use a Boxster/Cayman G86-21 transmission? My engine is the FWD version as it's more plentiful and much cheaper. The RWD 350z/G35/etc tend to get thrashed. FWD has the starter on the trans, no provision on the engine side. Box6 disadvantages: making a starter fit 175 lbs short gearing have to buy or make flywheel small dia bellhousing Not going to cost $100 Suby advantages: bolt on starter 100 lbs plenty of conversions to work from decent gearing coupler & axles & plate $300-500 Here is the kicker... Suby flywheel bolts on with a spacer which allows me to use all stock parts. I can make the adapter. Only cost $100 (IMG:style_emoticons/default/piratenanner.gif) It's really a no brainer on my end. The starter is not a big deal to remedy, but I can't beat a 6 speed trans for $100.00. Post picts. I want to see this setup. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:49 PM |
