Sand blaster chassis then what ?, What would do next ? |
nathanxnathan |
Jul 29 2022, 12:03 AM
Member Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Oh goodie! I get to be the contrarian again. (IMG:style_emoticons/default/biggrin.gif) I glass blasted my car myself. One of the least fun things a person can spend time doing, but it saved $. I had the car on a rotisserie which really helped rid the car of media. A few hours with shop vac, air hose, and spinning, spinning, spinning, the rotisserie as I worked. I haven't found a grain of media afterward. Not saying it was easy, but I'm not sorry I did it and don't know how I would have gotten the chassis to bare metal without blasting. Once down to bare metal, treat with Ospho and then epoxy primer. The Ospho kills any rust that might still be lurking, creates a protective coating to prevent flash rust, and it improves adhesion of the epoxy. PPG recommends phosphoric acid treatment to promote adhesion of their DPLF epoxy. I think it helps that you can turn the car upside down. Repeated compressed air and vacuuming help to be sure. Certain areas though... I'll be pounding on the car and look, say in the fuel tank area, and see that glass bead is coming out of a support/closed off area that I didn't think was open. There are so many places for it to get stuck in. I will say that the plusses of spot glass bead blasting keep me going back to it despite the havoc it brings. I think if the car is stripped and you are going deep there's a place for it. |
bbrock |
Jul 29 2022, 07:53 AM
Certain areas though... I'll be pounding on the car and look, say in the fuel tank area, and see that glass bead is coming out of a support/closed off area that I didn't think was open. There are so many places for it to get stuck in. This is a super important point. This was probably one advantage to spending 3 years repairing EXTENSIVE rust. By the time I got to blasting, I knew ever hole and crevice in the car and knew all the places that needed to be blown and sucked out. Every structural member is hollow inside and designed to allow condensation and water to drain out. That means there is a way for blasting media to get in, and a way to get it out with the right tools. I should also add that I live any a very low humidity area so the media didn't cake up. I doubt I would have had the same success in a high humidity place. |
Jul 29 2022, 08:48 AM
914-6 GT in waiting Group: Members Posts: 19,310 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Gotta love the east coast
JmuRiz |
Jul 29 2022, 09:05 AM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
No joke, the outside of my windows are foggy today...crazy
NARP74 |
Jul 29 2022, 09:37 AM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
And the inside of your car is rusty!
racer914 |
Jul 29 2022, 11:05 AM
Member Group: Members Posts: 81 Joined: 1-October 19 From: Keystone Heights, FL Member No.: 23,513 Region Association: South East States |
I had the bottom of my project done with a water/glass bead blast. It was very economical and the result was better than expected.
nivekdodge |
Jul 29 2022, 11:50 AM
Member Group: Members Posts: 250 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
20 years as a painter and then 20 as the local paint guy.
1.Rust gets almost everywhere, sand gets almost everywhere, acid almost gets everywhere. 2.The only people who had a chance at this not rusting back were the Germans 50 years ago when the metal was still pristine. If you have a 10 year old pickup truck you know about rust between two pieces of metal. 3. I stripped my outer panels with liquid and mechanical. Don't sandblast outer panels. You will warp them. The inner panels I did a combo of liquid, wire brush and mechanical.then sand blasting. 4. The Eastwood thing works great on truck frame rails. Not these body panels. 5. it either time or dollars, 6. blowing the sand out takes time. less with two airlines.Less with a spit. I spun mine every night and still got sand. I did a drag car years ago and everytime the wheels come back down, sand falls. How much is dipping? you MUST get the primer dipped also. Kevin |
930cabman |
Jul 29 2022, 12:52 PM
Advanced Member Group: Members Posts: 3,139 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
20 years as a painter and then 20 as the local paint guy. 1.Rust gets almost everywhere, sand gets almost everywhere, acid almost gets everywhere. 2.The only people who had a chance at this not rusting back were the Germans 50 years ago when the metal was still pristine. If you have a 10 year old pickup truck you know about rust between two pieces of metal. 3. I stripped my outer panels with liquid and mechanical. Don't sandblast outer panels. You will warp them. The inner panels I did a combo of liquid, wire brush and mechanical.then sand blasting. 4. The Eastwood thing works great on truck frame rails. Not these body panels. 5. it either time or dollars, 6. blowing the sand out takes time. less with two airlines.Less with a spit. I spun mine every night and still got sand. I did a drag car years ago and everytime the wheels come back down, sand falls. How much is dipping? you MUST get the primer dipped also. Kevin Kevin, Sounds as the voice of experience, there is no easy answer. I can recall blasting a pre-A speedster in the early 1970's with silica (without a mask) and there was sand everywhere, probably still is |
Lo-Fi Version | Time is now: 5th June 2024 - 05:09 AM |
