914-6 conversion throttle bellcrank addition, Where to mount it? |
Dec 13 2022, 07:44 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
PMS sells a long cable if you don't want to use the bellcrank.
NARP74 |
Dec 14 2022, 11:08 AM
Senior Member Group: Members Posts: 1,072 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Threadjack! Sorry... I'll open a new one if needed but decided it would be good to have it all in one place for searches.
What I have: 914 stock accel cable using the cruise control bracket on the 3.2 engine in a 914. Throttle linkage brackets, with the dual spring attachment, unused but installed. What I don't have: The shaft pull rod, stock return springs, the $100 coat hanger or the bell crank. What I think I want: Stock 914 cable, alternate, stock 911 cable, with a way to secure and adjust the cable Stock shaft pull rod Stock return springs X3 Trying to eliminate the bell crank and expensive coat hanger and go right to the throttle linkage bracket with the dual spring attachment. Don't want to reinvent the wheel just looking for a better option than I currently have. |
Dec 15 2022, 10:28 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
PMS sells a long cable if you don't want to use the bellcrank. Correct. I think mine is actually just an aftermarket 914/6 cable. Not sure if i got this from PMS or somewhere else. The throttle cable is simply looped upwards, routed through the slit for the linkage and connects directly to the throttle body on the engine. (IMG:style_emoticons/default/bye1.gif) |
NARP74 |
Dec 15 2022, 10:38 AM
PMS sells a long cable if you don't want to use the bellcrank. Correct. I think mine is actually just an aftermarket 914/6 cable. Not sure if i got this from PMS or somewhere else. The throttle cable is simply looped upwards, routed through the slit for the linkage and connects directly to the throttle body on the engine. (IMG:style_emoticons/default/bye1.gif) @SirAndy I have heard a std 914-6 cable works and has the correct ends on it. How are you securing the engine end of the accel cable? Is it adjustable for slack over time? Got any pics? |
Dec 15 2022, 04:46 PM
I have heard a std 914-6 cable works and has the correct ends on it. How are you securing the engine end of the accel cable? Is it adjustable for slack over time? Got any pics? No pics but it has a metal sleeve at the end where it hooks into the throttle body receiver. I don't remember if there is an adjustment on the engine end. It's been 15 years since i last had to look at that part. (IMG:style_emoticons/default/biggrin.gif) |
NARP74 |
Dec 15 2022, 05:24 PM
It's reliable then!
mb911 |
Dec 15 2022, 08:27 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
NARP74 |
Dec 15 2022, 09:43 PM
I know, that is why I want to try and duplicate it. Having trouble getting details on it though. |
mb911 |
Dec 16 2022, 06:32 AM
I know, that is why I want to try and duplicate it. Having trouble getting details on it though. I will be installing one on a customer conversion car with CIS over the next few weeks so will have my information at that time |
mlindner |
Dec 16 2022, 07:39 AM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
NARP74 |
Dec 16 2022, 09:49 AM
I have seen 2 or 3 options for the bell crank attachment on the 901 trans. They are all very nice. I am trying to eliminate that and the coat hanger and go to the next connection point just through the hole in the tin. Still keeping as much stock as possible. 914 or 914-6 accel cable is fine, even a 911 cable would be fine if I have to for the right connections on the end. I need a way to secure the cable end and be slightly adjustable at that next connection point.
Might be a waste of time but it is just research at the moment. |
mlindner |
Dec 18 2022, 03:53 PM
I'm not sure why you would want to eliminate the bell crank. It's simple, it works, it is adjustable, it aligns well with the carbs. Best, Mark
NARP74 |
Dec 18 2022, 04:52 PM
I'm not sure why you would want to eliminate the bell crank. It's simple, it works, it is adjustable, it aligns well with the carbs. Best, Mark Just seems like extra connections and parts that are not needed. I am running FI. Plus I do not have some of those parts and that stupid coat hanger is expensive! So is the bell crank modified to fit a 901. Probably $600 or more to get it working in my car. |
Dec 18 2022, 09:24 PM
Should be around $250. Rich makes and sells the kit for about that much and if you have an early intermediate plate, you don’t need the bolt on adaptor. I’m not sure where you are getting $600.
NARP74 |
Dec 19 2022, 12:04 AM
Should be around $250. Rich makes and sells the kit for about that much and if you have an early intermediate plate, you don’t need the bolt on adaptor. I’m not sure where you are getting $600. His kit is $475 and I am still missing more parts. And I might want a spare 914-6 accel cable just in case, more $$$. No complaints with his kit, just trying to avoid using it. |
Dec 19 2022, 07:54 AM
Should be around $250. Rich makes and sells the kit for about that much and if you have an early intermediate plate, you don’t need the bolt on adaptor. I’m not sure where you are getting $600. His kit is $475 and I an still missing more parts. And I might want a spare 914-6 accel cable just in case, more $$$. No complaints with his kit, just trying to avoid using it. I didn’t realize prices had gone up that much. |
NARP74 |
Dec 19 2022, 08:55 AM
Everything has unfortunately.
I was looking to buy something for the car 2 weeks ago, while I looked at it and put it in the cart, the price went from 225 to 315. The site had been adjusting their prices while I shopped. http://www.autoatlanta.com/Porsche-Acceler...9146ALKDME.html |
Dec 19 2022, 09:53 AM
Everything has unfortunately. I was looking to buy something for the car 2 weeks ago, while I looked at it and put it in the cart, the price went from 225 to 315. The site had been adjusting their prices while I shopped. http://www.autoatlanta.com/Porsche-Acceler...9146ALKDME.html Yea, that’s the Rich Johnson kit. |
Lo-Fi Version | Time is now: 31st May 2024 - 10:07 PM |
