Wiper motor repair, Removing mechanism |
Ishley |
Aug 10 2022, 06:31 AM
Member Group: Members Posts: 96 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
When I got my 72, 1.7 the fan and the wipers did not work. I knew the fan was likely full of debris as the grill was off on top of the unit. I got the blower out and cleaned everything out and tested… all is good.
Now I’m trying to remove the wiper mechanism as I want to test the motor and checkout/cleanup the mechanism. I can’t get it out. I know there is a back nut to remove under the dash. I think I can feel it when I reach way up under the dash. I’ve searched the forums and can’t find a procedure. I think I saw a post once to remove the gauge cluster to get to the nut. Is this the best way to get to it? Can it be done without taking the gauges out? Thanks in advance for help from those who have done this. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:52 PM |
