Fender flairs for a 10" rear wheel in steel ? |
914GTSTI |
Aug 10 2022, 06:40 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Been looking at my 914 project and need some help. Thinking of using a 295/50r15 on a 10" x 15" x -35 offset. Is their a steel flair that can do this using the 914GT look ?
Thanks |
Aug 10 2022, 07:10 PM
914-6 GT in waiting Group: Members Posts: 19,286 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Nothing stock. A couple people have widened their steel flares.
Ron S. comes to mind. http://www.914world.com/bbs2/index.php?sho...03&hl=Flare Attached image(s) |
Aug 10 2022, 08:09 PM
Resident German Group: Admin Posts: 41,656 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
10" is not going to work under stock rear flares.
The available space is pretty much exactly 10" (with rolled inner lip) and there's no room to spare. So even with the perfect wheel offset, you will be rubbing tires the moment the suspension moves. Now, if you had enough clearance on the inside, you *could* take a baseball bat to the outside and roll the whole fender out until you get enough space. Or, do what is shown above and splice in an inch or so to give you enough space. (IMG:style_emoticons/default/popcorn[1].gif) |
ConeDodger |
Aug 10 2022, 10:13 PM
Apex killer! Group: Members Posts: 23,598 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
This is two 16X6 wheels made in to one 16X8.5. The reproduction flares have more flange on them than the factory so the flange had to be ‘nibbled’ a bit. Harvey played with the offset a bit to make these work, but I’d guess they are the limit without sectioning and metalworking additional width on the flares.
Please excuse the unpainted flare. It looks better now. Attached thumbnail(s) Attached image(s) |
infraredcalvin |
Aug 10 2022, 10:16 PM
Distracted Member Group: Members Posts: 1,520 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
You may want to be sure whatever brakes you use fit under those 15” wheels. I know 993TT
I’m assuming with those fat tires you’ve got power, and hopefully a nice braking system… Edit:fixed erroneous info |
Aug 10 2022, 10:21 PM
Boxster calipers will usually fit a 15” Fuchs or cookie. They often don’t fit on reproduction Fuchs. We put a lot of Boxster calipers on project cars when I worked at the Porsche shop.
914GTSTI |
Aug 10 2022, 10:43 PM
Thanks.
I was looking at Ron s's fenders and was thinking that will be the way to go ? What is the max wheel that will fit the GT flair ? 8" ? |
914GTSTI |
Aug 10 2022, 10:57 PM
Maybe some thing like a 265/50r15 on a 8" x 15" x -16. That could work ?
As for brakes I was thinking about the Boxster but have never worked on them. I did get a set of Boxster hubs to work with but never got any further with them.Think their is a photo here installing them on my trailing arms. |
Aug 11 2022, 07:23 AM
Thanks. I was looking at Ron s's fenders and was thinking that will be the way to go ? What is the max wheel that will fit the GT flair ? 8" ? It's really about the wheel tire combo. You may be able to fit 9's but it won't be with a fat tire. Look at it this way, a stock 914 will comfortably take a 6" wheel with a 205x60 tire. Flares generally add 2" of width. Anything more needs modification (rolling the lip, tugging the fender, adding metal) If you use Boxster calipers, remember, you need the standard ones, not the S version. |
Aug 11 2022, 09:52 AM
It's really about the wheel tire combo. You may be able to fit 9's but it won't be with a fat tire. (IMG:style_emoticons/default/agree.gif) The absolute max i can run on my car is 9.5" wide tires. That's with wheel spacers to get the perfect offset. I have the outer fender lip completely shaved off and i can't get my pinky between the tires and the fender. http://www.914world.com/bbs2/index.php?s=&...t&p=2892794 (IMG:style_emoticons/default/driving.gif) 23.0x9.5x15 on 7x15 cookie cutters with Boxster calipers (IMG:http://www.914world.com/bbs2/uploads/post-179-1613773293_thumb.jpg) |
Aug 11 2022, 11:34 AM
It's really about the wheel tire combo. You may be able to fit 9's but it won't be with a fat tire. (IMG:style_emoticons/default/agree.gif) The absolute max i can run on my car is 9.5" wide tires. That's with wheel spacers to get the perfect offset. I have the outer fender lip completely shaved off and i can't get my pinky between the tires and the fender. http://www.914world.com/bbs2/index.php?s=&...t&p=2892794 (IMG:style_emoticons/default/driving.gif) 23.0x9.5x15 on 7x15 cookie cutters with Boxster calipers Andy - Are you fenders glass. They run a slight bit wider if I recall. Maybe since they bond to the fender instead of but welding. If I’m wrong about the glass, Fuhgeddaboudit |
tygaboy |
Aug 11 2022, 12:23 PM
914 Guru Group: Members Posts: 5,297 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
These are Ronals. Fronts are 8x16, same offset as the Fuchs 8", running 225/50 and no spacers.
Rears are 16x 9, but where the Fuchs 9" is a -15 offset, these happen to be -13. Running 245/45 and no spacers. They fill up standard steel GT flares really nicely, IMO. Attached thumbnail(s) |
Aug 11 2022, 03:56 PM
It's really about the wheel tire combo. You may be able to fit 9's but it won't be with a fat tire. (IMG:style_emoticons/default/agree.gif) The absolute max i can run on my car is 9.5" wide tires. That's with wheel spacers to get the perfect offset. I have the outer fender lip completely shaved off and i can't get my pinky between the tires and the fender. http://www.914world.com/bbs2/index.php?s=&...t&p=2892794 (IMG:style_emoticons/default/driving.gif) 23.0x9.5x15 on 7x15 cookie cutters with Boxster calipers Andy - Are you fenders glass. They run a slight bit wider if I recall. Maybe since they bond to the fender instead of but welding. If I’m wrong about the glass, Fuhgeddaboudit Glass. And with all the bondo on this car, i wouldn't be surprised if i had an extra 1/4" of space under there. (IMG:style_emoticons/default/biggrin.gif) |
914GTSTI |
Aug 11 2022, 05:23 PM
Is their a list of gauges of metal on the 914 and where it is used on the car ?
rick 918-S |
Aug 12 2022, 07:59 AM
Hey nice rack! -Celette Group: Members Posts: 20,468 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
914GTSTI |
Aug 12 2022, 10:27 AM
Thanks for the link.
914werke |
Aug 12 2022, 10:31 AM
"I got blisters on me fingers" Group: Members Posts: 10,097 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
To run that big meat I hope you have a lot of motor ~
914GTSTI |
Aug 12 2022, 08:03 PM
Good point.
If I go with the 2.0 V2 STI, something like 200 to 300 at the wheels +-. Its all boost . Still not sure about the 4 cylinder ? Had that motor in my Rally Forster. This has a poor sound, Or I go with a EZ 30-33-36 ? This would be a N/A motor. Maybe 250 to 300 +- ? This has the sound that is more like the 6 used in the 914-6. Love the sound. Sounds funny, to have it to come down to sound. |
sixnotfour |
Aug 12 2022, 08:12 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
11.5 x 17 315/35 tires
914GTSTI |
Aug 12 2022, 08:28 PM
Nice ! What size up front ? Looks like 8" ?
Lo-Fi Version | Time is now: 25th May 2024 - 12:41 AM |
