Monaco Of Autocross |
yeahmag |
Aug 23 2022, 07:53 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
This weekend was one of, if not my favorite event with PCA: San Pedro Autocross. This is hosted near the Lane Victory and Battleship Iowa, surrounded on 3 sides by water. We managed to start to tear the front sway bar out, so I have the reinforcement plates ready to go. Evan ended up in 2nd in CC07 and I ended up in 3rd. The newer hardware is getting hard to keep up with. A modified BRZ beat Evan by .500s
https://www.youtube.com/watch?v=kdgfVJpRpUM https://www.youtube.com/watch?v=H7IcpFuyFWE |
brilliantrot |
Aug 28 2022, 09:31 AM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
We usually do better against the newer cars, this venue is just bumpy and I can’t go full attack all the time with the bumps. We are running 550lb/in rear springs and some Penske shocks trying to keep the front wheels closer to the ground and off the bump stops but the car is not a fan of bumps. Spring rates much lower though and it is into the bump stops a lot with the Hoosier tires and makes for some spikie handling. We are somewhere on the limit of how stiff you can make the car where chassis flex is starting to equal suspension compression.
Aaron just put on the Tangerine exhaust and I think it has 1 3/4” primaries………. That killed the bottom end a bit but made it pull better up top. It’s definitely harder to launch now. With the old header with smaller primaries, it pulled great off idle but now with the big exhaust, you don’t want to go full throttle under 2500 rpm as it’s a little boggy. Not an issue for Autocross or anything over parking lot speeds though. It’s got not too wild of a cam with an 86a grind from web. All around it’s the best T4 I’ve driven. Probably the best complement was a guy at this past autocross came up and asked if the car was Honda K swapped. Aaron is working on putting together a 2270 stroker with some heads of Dave Finch’s FP car with forged internals and a bigger cam…… can’t wait for that to be done and it should be good to 8000+. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:25 AM |
