Plated Parts Color, Silver or Gold |
DennisV |
Sep 1 2022, 10:56 AM
Member Group: Members Posts: 468 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
What color was original plated hardware? Silver / clear or Gold / yellow? I am particularly interested in 1970 914-6 engine area at the moment, if the year or -6 matters.
I've seen some threads on hardware and kits, but they seem to be focused on personal preferences rather than what was original. Thanks. P.S. It was a much easier decision on the 356! I don't think there was gold anything on that car, unless your name was Harry Pellow. (IMG:style_emoticons/default/biggrin.gif) |
DennisV |
Sep 1 2022, 01:18 PM
There is a thread on the Early 911S Registry forum that sounds pretty convincing and applicable to all Porsche's regardless of model.
So that would suggest that all 914 and 914-6 hardware would have had zinc with yellow chromate finish. Please chime in if anyone has information to the contrary. Otherwise, I guess we're going gold baby. (IMG:style_emoticons/default/smilie_pokal.gif) |
Eric_Shea |
Dec 2 2022, 10:56 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yellow Zinc Dichromate on almost everything on the car.
Some exceptions are the triangle headlight armature mounting plates that show on the side of the headlight buckets and their counterparts in the fender. Also the door latches and latch plates. These are clear zinc. Hope that helps, E. |
Mikey914 |
Dec 2 2022, 11:12 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I thought they used Hex chrome. It really is the best product, just not available.
friethmiller |
Dec 2 2022, 12:04 PM
Member Group: Members Posts: 468 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Yellow Zinc Dichromate on almost everything on the car. Some exceptions are the triangle headlight armature mounting plates that show on the side of the headlight buckets and their counterparts in the fender. Also the door latches and latch plates. These are clear zinc. Hope that helps, E. (IMG:style_emoticons/default/agree.gif) I used blue chromate on my latch plates. I think this is either the same or close to what Eric mentioned. Also, I think the rear trunk latch (receiver) is something else. I plated mine with zinc-nickel as an experiment. Worked great, IMHO. |
Eric_Shea |
Dec 2 2022, 12:25 PM
Pot metal/Alloy casting. We glass bead those.
mepstein |
Dec 2 2022, 12:28 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
friethmiller |
Dec 2 2022, 01:16 PM
Pot metal/Alloy casting. We glass bead those. Don’t throw them in with the zinc plating. They will dissolve. Same with the pull knob for the front trunk. Ask me how I know - lol! Door stays are silver. LOL! yeah, so don't plate the bottom latch. Maybe the nickel saved them from damage? Good to know for next time, though. |
mb911 |
Dec 3 2022, 07:07 AM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Pot metal/Alloy casting. We glass bead those. Don’t throw them in with the zinc plating. They will dissolve. Same with the pull knob for the front trunk. Ask me how I know - lol! Door stays are silver. Yup that was my fault when I dropped them off at the players for you. Should have known. |
mepstein |
Dec 3 2022, 08:03 AM
Pot metal/Alloy casting. We glass bead those. Don’t throw them in with the zinc plating. They will dissolve. Same with the pull knob for the front trunk. Ask me how I know - lol! Door stays are silver. Yup that was my fault when I dropped them off at the players for you. Should have known. No, my fault. Learning experience. Luckily they are cheap and plentiful. |
Eric_Shea |
Dec 5 2022, 08:05 PM
They don't dissolve in the zinc.
They dissolve in the hydrochloric acid that they pickle them with in advance. If they're cleaned and dipped in a mild hydrochloric solution then or "watched" they'll be fine to plate. It's just the wrong finish though... |
rgalla9146 |
Dec 6 2022, 01:14 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Yellow Zinc Dichromate on almost everything on the car. Some exceptions are the triangle headlight armature mounting plates that show on the side of the headlight buckets and their counterparts in the fender. Also the door latches and latch plates. These are clear zinc. Hope that helps, E. I think the big beefy seat belt washers were also clear zinc |
StarBear |
Dec 6 2022, 02:02 PM
Senior Member Group: Members Posts: 1,858 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Yellow Zinc Dichromate on almost everything on the car. Some exceptions are the triangle headlight armature mounting plates that show on the side of the headlight buckets and their counterparts in the fender. Also the door latches and latch plates. These are clear zinc. Hope that helps, E. I think the big beefy seat belt washers were also clear zinc Rory; just replaced mine; mine were yellow zinc, hence the difficulty in getting accurate replacements. Edit |
Lo-Fi Version | Time is now: 4th May 2024 - 10:15 PM |
