swap rims 15" to 16", offset in rims |
-=rafal=- |
Sep 5 2022, 05:14 AM
Newbie Group: Members Posts: 10 Joined: 5-September 22 From: Poland Member No.: 26,820 Region Association: None |
Hi, I've been browsing the forum and similar topics have been described several times, but nowhere did I know what interests me. I have a few questions because more knowledge than me. What offset are the original Porsche 914 alloy wheels in a narrow body style? I was looking at ebay auctions, on forums, on facebook and they all only give the size and width (15x5.5), the PET porsche also doesn't have any offset. I bought a porsche 914 which has no original rims. I checked the parameters and there is information 15x5.5 but there is no offset anywhere on the rim. I would like to change the rims. I would like to change the rims (currently 15x5.5 tire 185x65x15) to 16x6.5 or 16x7 with a 195x50x16 or 195x55x16 tire and if anyone can tell me exactly what offset I need in 16-inch rims so that the tire does not rub against the fenders at the back and with front when turning the wheels. Verified information would be the most important to me. My rims in the picture. Thank you very much for all your help and please be understanding if there are any spelling mistakes. Greetings from Poland (IMG:style_emoticons/default/beerchug.gif)
Attached thumbnail(s) |
Racer |
Sep 5 2022, 07:56 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
The 5.5 inch wheel has a 42mm offset.
Porsche 6x15 5 bolt Fuchs have a 36mm offset Porsche 7x15 5 bolt Fuchs have a 23.3 mm offset. The ultrarare 7x15 911r wheel has a 49mm offset. There are threads galore about "will this wheel / tire combo fit" , so please read through them. For 4 bolt wheels, your options may be more limited than the 5 bolt wheels and be mindful that "VW" wheels are often either narrower, or have a different offset. When going larger than 6 inch wide, ride height, camber, spring rate, rolled fender lips and tire size all come into play. Imho, the best find widest used wheel that fits easiest is the 6.5x15 minilite with a 205/50 tire. If you swap to Porsche 5 bolt wheels, the 6x15 is the easiest to fit. The rear of these cars is where fitment gets harder than the front, unless you add flares. |
Sep 5 2022, 08:13 AM
914-6 GT in waiting Group: Members Posts: 19,275 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 5.5 inch wheel has a 42mm offset. Porsche 6x15 5 bolt Fuchs have a 36mm offset Porsche 7x15 5 bolt Fuchs have a 23.3 mm offset. The ultrarare 7x15 911r wheel has a 49mm offset. There are threads galore about "will this wheel / tire combo fit" , so please read through them. For 4 bolt wheels, your options may be more limited than the 5 bolt wheels and be mindful that "VW" wheels are often either narrower, or have a different offset. When going larger than 6 inch wide, ride height, camber, spring rate, rolled fender lips and tire size all come into play. Imho, the best find widest used wheel that fits easiest is the 6.5x15 minilite with a 205/50 tire. If you swap to Porsche 5 bolt wheels, the 6x15 is the easiest to fit. The rear of these cars is where fitment gets harder than the front, unless you add flares. (IMG:style_emoticons/default/agree.gif) Very good info. 6” cookies also fit well if you are looking for a good budget wheel. |
JamesM |
Sep 6 2022, 12:47 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I assume you are talking about a 4 bolt, narrow body car?
If you want to run 16x7 you will want an ET35 offset, most cars will be able to fit up to 205s with that depending on the tire. I know a few people running these, including myself. https://www.vtowheels.com/1969-1976_c_1706.html Hi, I've been browsing the forum and similar topics have been described several times, but nowhere did I know what interests me. I have a few questions because more knowledge than me. What oats are the original Porsche 914 alloy wheels in a narrow body style? I was looking at ebay auctions, on forums, on facebook and they all only give the size and width (15x5.5), the PET porsche also doesn't have any oats. I bought a porsche 914 which has no original rims. I checked the parameters and there is information 15x5.5 but there is no offset anywhere on the rim. I would like to change the rims. I would like to change the rims (currently 15x5.5 tire 185x65x15) to 16x6.5 or 16x7 with a 195x50x16 or 195x55x16 tire and if anyone can tell me exactly what offset I need in 16-inch rims so that the tire does not rub against the fenders at the back and with front when turning the wheels. Verified information would be the most important to me. My rims in the picture. Thank you very much for all your help and please be understanding if there are any spelling mistakes. Greetings from Poland (IMG:style_emoticons/default/beerchug.gif) |
-=rafal=- |
Sep 6 2022, 02:11 AM
The 5.5 inch wheel has a 42mm offset. Porsche 6x15 5 bolt Fuchs have a 36mm offset Porsche 7x15 5 bolt Fuchs have a 23.3 mm offset. The ultrarare 7x15 911r wheel has a 49mm offset. There are threads galore about "will this wheel / tire combo fit" , so please read through them. For 4 bolt wheels, your options may be more limited than the 5 bolt wheels and be mindful that "VW" wheels are often either narrower, or have a different offset. When going larger than 6 inch wide, ride height, camber, spring rate, rolled fender lips and tire size all come into play. Imho, the best find widest used wheel that fits easiest is the 6.5x15 minilite with a 205/50 tire. If you swap to Porsche 5 bolt wheels, the 6x15 is the easiest to fit. The rear of these cars is where fitment gets harder than the front, unless you add flares. Thank you for the information - they are very helpful. I do not want to change the rims to other original ones that were factory-fitted, and I will not change four bolts to five bolts. I want to make custom rims on a CNC machine - this will be my pattern and that's why I need parameters. I noticed that in the USA people choose wheels according to the width of the rim and the width of the tire, and in Europe, people choose the wheels according to the width of the rim and the offset, and finally they choose the tire so that it fits and does not rub against the body. That's why I had a problem with finding a topic that interests me on the forum. Do you know exactly what parameters of 16-inch rims must be (width, offset) so that there is no problem? I want a narrower tire, i.e. 185x55x16 or 195x50x16. I was planning to build myself 6.5 inch wide 16 "rims, but I don't know what offset. Thank you for your help |
-=rafal=- |
Sep 6 2022, 02:13 AM
I assume you are talking about a 4 bolt, narrow body car? If you want to run 16x7 you will want an ET35 offset, most cars will be able to fit up to 205s with that depending on the tire. I know a few people running these, including myself. https://www.vtowheels.com/1969-1976_c_1706.html Great, thank you for the information. So if I have a 16x6.5 ET35 rim and mount a tire, for example 185x55x16 or 195x55x16, should everything be perfect? |
JamesM |
Sep 6 2022, 12:31 PM
I assume you are talking about a 4 bolt, narrow body car? If you want to run 16x7 you will want an ET35 offset, most cars will be able to fit up to 205s with that depending on the tire. I know a few people running these, including myself. https://www.vtowheels.com/1969-1976_c_1706.html Great, thank you for the information. So if I have a 16x6.5 ET35 rim and mount a tire, for example 185x55x16 or 195x55x16, should everything be perfect? I have never seen anything that fits perfect on these cars as they were hand built and all have some level of variance, but a 16x6.5 ET35 running a 185 or 195 width tire you should be ok. |
brant |
Sep 6 2022, 03:40 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The offsets of a 7R wheel would be the perfect choice
It’s how the factory did it when they wanted to fit a 7 inch wide rim for racing |
-=rafal=- |
Sep 6 2022, 11:18 PM
The offsets of a 7R wheel would be the perfect choice It’s how the factory did it when they wanted to fit a 7 inch wide rim for racing Thank you for your answer, I do not understand what 7R means, I have not encountered such an offset. can you explain to me? thank you. |
brant |
Sep 7 2022, 06:57 AM
7R is the name of a model of Fuchs wheel
It was the factory race wheel Thus the R I believe the 914 fenders were designed around the 14 inch Fuchs As that was the original wheel on the -6 The offset of a 14 inch Fuchs is only a couple of mm away from a 7R wheel Either of those wheels would be the correct range to copy Can someone post the Fuchs offset chart? I don’t have it But it shows the offset for all of the different Fuchs |
914werke |
Sep 7 2022, 09:27 AM
"I got blisters on me fingers" Group: Members Posts: 10,072 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
brant |
Sep 7 2022, 10:16 AM
Thanks Rich !
and the 14inch fuchs is not on the chart. but my memory is that it is 47mm offset... or very very close to the 7R wheel I bought a set of 14inch fuchs from a member here that were original to his 914/6 he had 215 tires on those wheels under stock fenders... due to the correct offset thus it is my belief that the factory designed the fenders around that offset and that wheel (the original wheel on these cars) brant |
-=rafal=- |
Sep 8 2022, 01:17 AM
7R is the name of a model of Fuchs wheel It was the factory race wheel Thus the R I believe the 914 fenders were designed around the 14 inch Fuchs As that was the original wheel on the -6 The offset of a 14 inch Fuchs is only a couple of mm away from a 7R wheel Either of those wheels would be the correct range to copy Can someone post the Fuchs offset chart? I don’t have it But it shows the offset for all of the different Fuchs thank you for explaining |
-=rafal=- |
Sep 8 2022, 01:55 AM
Thanks Rich ! and the 14inch fuchs is not on the chart. but my memory is that it is 47mm offset... or very very close to the 7R wheel I bought a set of 14inch fuchs from a member here that were original to his 914/6 he had 215 tires on those wheels under stock fenders... due to the correct offset thus it is my belief that the factory designed the fenders around that offset and that wheel (the original wheel on these cars) brant In conclusion, if I have a 16x6.5 ET35 rim and mount a tire, for example, 185x55x16 or 195x55x16, everything should be perfect? |
brant |
Sep 8 2022, 07:00 AM
Thanks Rich ! and the 14inch fuchs is not on the chart. but my memory is that it is 47mm offset... or very very close to the 7R wheel I bought a set of 14inch fuchs from a member here that were original to his 914/6 he had 215 tires on those wheels under stock fenders... due to the correct offset thus it is my belief that the factory designed the fenders around that offset and that wheel (the original wheel on these cars) brant In conclusion, if I have a 16x6.5 ET35 rim and mount a tire, for example, 185x55x16 or 195x55x16, everything should be perfect? Probably A 6 inch rim for sure But using the 47 offset would work better and guarantee the 6.5 inch (or even 7 inch) would fit |
-=rafal=- |
Sep 13 2022, 01:12 AM
JamesM |
Sep 13 2022, 02:27 PM
Thanks Rich ! and the 14inch fuchs is not on the chart. but my memory is that it is 47mm offset... or very very close to the 7R wheel I bought a set of 14inch fuchs from a member here that were original to his 914/6 he had 215 tires on those wheels under stock fenders... due to the correct offset thus it is my belief that the factory designed the fenders around that offset and that wheel (the original wheel on these cars) brant Im running 16x7 ET35 with 215s and they are just barely rubbing the paint off my strut covers in the front and inner chassis at the rear (this is with autox tire flexing). would be full interference at 47mm, at least with a 7" wide wheel |
SKL1 |
Sep 13 2022, 02:39 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I have the 16" front Fuchs from a G body 911 (SC) with 205//50/16's front and rear on both my cars with no rubbing issues. Have run them for years...
Lo-Fi Version | Time is now: 19th May 2024 - 09:19 AM |
