MPS Stop Screw, Need tap size |
saigon71 |
Sep 11 2022, 05:58 AM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm rebuilding a manifold pressure sensor. Unfortunately, I chewed up the threads on the MPS while removing the epoxy and backing out the stop screw. (IMG:style_emoticons/default/mad.gif)
I need to pick up a tap to clean the threads. Does anyone know what size & pitch these threads are? Thank you. |
tvdinnerbythepool |
Sep 11 2022, 01:45 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
I'm rebuilding a manifold pressure sensor. Unfortunately, I chewed up the threads on the MPS while removing the epoxy and backing out the stop screw. (IMG:style_emoticons/default/mad.gif) I need to pick up a tap to clean the threads. Does anyone know what size & pitch these threads are? Thank you. Tangerine can help with this! I did the same thing and they rescued my case for me. |
rjames |
Sep 11 2022, 02:16 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I'm rebuilding a manifold pressure sensor. Unfortunately, I chewed up the threads on the MPS while removing the epoxy and backing out the stop screw. (IMG:style_emoticons/default/mad.gif) I need to pick up a tap to clean the threads. Does anyone know what size & pitch these threads are? Thank you. I'd like to know, too. I've also got one I buggered up that could be saved. |
BeatNavy |
Sep 11 2022, 03:26 PM
I went out to the garage to check for you but only have a partial answer:
It is size 16, and I THINK the pitch is 1.5. But I'm not willing to bet my life on that. I don't have the bolt gauge for that size, and I don't have a tap that's 1.0 pitch for that size, so that's the best I can do. @ChrisFoley |
JeffBowlsby |
Sep 11 2022, 03:43 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It’s M16x1.0
ChrisFoley |
Sep 12 2022, 04:18 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Bob, I can chase the threads for you, just for the cost of shipping.
You can use a smaller diameter tap with the same pitch to scrape the threads. Doing that saves one from buying an expensive tap with no other use. |
saigon71 |
Sep 12 2022, 06:39 AM
Thank you for the responses and for your kind offer Chris.
I found a cheap M16 X 1.0 tap & die on ebay and bought it in case I run into this problem again. Here is the link if anyone is interested: https://www.ebay.com/itm/155000606646?chn=p...axoCDYMQAvD_BwE (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:48 AM |
