jim dorociak |
Member ![]() ![]() Group: Members Posts: 97 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California ![]() ![]() |
guys I just picked up new Boge rear shocks for my SIX. Is it a special spring perch or will anyone work? Thanks in advance. Been 30 years since I restored my last car so it is a lot learning to get back in the swing. Jim |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,807 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
guys I just picked up new Boge rear shocks for my SIX. Is it a special spring perch or will anyone work? Thanks in advance. Been 30 years since I restored my last car so it is a lot learning to get back in the swing. Jim not sure about 6. but ones that i pulled off my 4 had built in bottom spring perch. one fixed position. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,772 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Boge was the OE supplier. Pics would help. But pretty certain the stock deep stamped lower perch will do the trick. BUT..... they have no height adjustment. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
The perch is unique to Boge rear shocks. The three bumps on the shock body won't support other removable perches.
I've made a substitute before, I think using a cut off lower perch from a KYB. Maybe I can find a picture. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,022 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
guys I just picked up new Boge rear shocks for my SIX. Is it a special spring perch or will anyone work? Thanks in advance. Been 30 years since I restored my last car so it is a lot learning to get back in the swing. Jim @jim dorociak Pretty sure i have a pair of those perches if you need them. They are soecial to Boge Bruce |
Lo-Fi Version | Time is now: 4th July 2025 - 05:00 AM |
