Condenser Mounting Screw?, Installed Pertronix and the screw walked away... |
FlacaProductions |
Sep 15 2022, 09:56 AM
Senior Member Group: Members Posts: 1,590 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I installed a Pertronix and when going back to button everything up, I can't find the condenser mounting screw on the distributer. Anyone know the size/thread? Can't think that leaving that hole open is a good thing...
FlacaProductions |
Sep 15 2022, 05:51 PM
that's EXACTLY why I need the screw, Clay - took the condenser off when the Pertronix went in...
ClayPerrine |
Sep 15 2022, 10:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
that's EXACTLY why I need the screw, Clay - took the condenser off when the Pertronix went in... Ok.. I get it. You want to fill the hole, not re-mount the condenser. They are the same screw as used on the points wire bracket and the vacuum advance mounts. Take one out and go to your local Ace hardware. They can find you a screw with the same size length and thread pitch. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:18 PM |
