Case machining for 2270 build |
DaveB |
Sep 17 2022, 02:19 PM
Member Group: Members Posts: 165 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
My current engine build has been a less than stellar. Essentially nothing was been done for 6 months and my case is gone. Engines I have built from scratch are all water cooled and I hit the easy button having a shop build this for me. Plus I was being cheap. After spending the last few weeks figuring out the combination of what I need, I've narrowed down to an engineered kit for the 2270 175 from LN. I will pick-up a 1.7 case and see if European Motorworks will machine it. Before I talk with LN or the machine shop, I wanted to know from anyone that has either used one of the LN engine kits or built to 160+hp on what additional machining you had done on the case beyond aligning bore and decking. I plan to add:
shuffle pin in all mains, 10mm case savers, bore for 1/2" through bolts, drill tap oil galley in holes, drill and tap case for full flow The cylinders are 96mm, so I assume I don't need to bore the case for that. Any feedback on what you either have done or should have done helps. if there is a thread on this just point me there (I couldn't find one). Thanks DaveB |
Sep 17 2022, 03:15 PM
914-6 GT in waiting Group: Members Posts: 19,296 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would contact LN about your questions. He is very knowledgeable and responsive. Good luck with the build.
DaveB |
Sep 17 2022, 03:44 PM
I would contact LN about your questions. He is very knowledgeable and responsive. Good luck with the build. Thanks for the feedback and I plan to call the folks at LN next week. I often find out I should have asked about something recommended or used by others during the call. Dave |
barnfind9141972 |
Sep 17 2022, 11:05 PM
Member Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
Just call Jorge at European Motor Works. He’ll tell you exactly what it needs, he’s very straight forward and did my engine. Great guy, really knows his stuff
JamesJ |
Sep 18 2022, 03:43 PM
Member Group: Members Posts: 223 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
I highly recommend speaking with Jeff Patterson at Type IV Revolution. He buys the LN kits and modifies some things that improve the kit before assembly. type4revolution2@gmail.com.
I just had my 2056 built by European Motorworks as I only heard about/spoke with Jeff near the end of my build. Many here have had EM build their motor with great success. I had some things that needed to be corrected. I'll have Jeff do my next build. |
Dominic |
Sep 18 2022, 07:00 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Dave,
Do some research on the 1.7L case you may not need to machine it for the clearance, I know that the 2.0L cases need machining (see the pictures from the case case I did a few years back. For sure ask LN or Jake Raby. Thanks, Dominic Attached thumbnail(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 10:48 AM |
