Engine compartment relay/silver box - WTH is this thing?, Need to know if this Resistance module can be had new somewhere |
thewheel69 |
Sep 19 2022, 10:47 AM
Wazabi 1.8 Group: Members Posts: 54 Joined: 14-December 05 From: Fort Collins Member No.: 5,275 Region Association: Rocky Mountains |
So im trying to diagnose a stuttering issue that seems to occur after about 15 min. of drive time. She starts cutting out at low RPM and then will climb erratically if I mash the throttle. I have installed a new flame thrower coil which does seem to give her more pep but still having this stuttering issue after warm/hot.
I unplugged this resistor (I think thats the name) and the engine stopped so it must be important but the wires are very brittle and look to be about to pull out from the ceramic tubes/cylinders. Pelican says No Longer Available https://www.pelicanparts.com/More_Info/0229...mp;KeepHeader=Y Thanks for any insights as I have tried all the other diagnosis familiar to me. John Attached thumbnail(s) |
dr914@autoatlanta.com |
Sep 20 2022, 10:52 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the resistor block is not the problem, it only fails when one of the wires disattaches itself causing one cylinder not to fire. Try points condenser dwell timing firsts. Resistor blocks are totally available by the way
So im trying to diagnose a stuttering issue that seems to occur after about 15 min. of drive time. She starts cutting out at low RPM and then will climb erratically if I mash the throttle. I have installed a new flame thrower coil which does seem to give her more pep but still having this stuttering issue after warm/hot. I unplugged this resistor (I think thats the name) and the engine stopped so it must be important but the wires are very brittle and look to be about to pull out from the ceramic tubes/cylinders. Pelican says No Longer Available https://www.pelicanparts.com/More_Info/0229...mp;KeepHeader=Y Thanks for any insights as I have tried all the other diagnosis familiar to me. John |
Lo-Fi Version | Time is now: 17th May 2024 - 07:57 PM |
