Mobelwagen Wheels |
Mobelwagen Wheels |
Stratfink |
Sep 22 2022, 11:03 PM
Newbie Group: Members Posts: 39 Joined: 27-December 21 From: SoCal Member No.: 26,198 Region Association: Southern California |
Anyone run these Mobelwagen wheels?
I’m kind of diggin’ the interceptor, but the backspacing on the 15 x 5.5 is 4”. I think they’ll be fine with the 185’s that came with my car but would require some work on the rear fender lips if I ever move to 205’s. They do have the “schnell” for less money and proper backspacing - and kind of look like 4 lug aftermarket Fuchs. They’d go on this car. My 1st 914 that I recently acquired from TDSkip (thanks Tom!). |
Montreal914 |
Sep 28 2022, 01:28 AM
Senior Member Group: Members Posts: 1,543 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Question: How do you balance these wheels? The wheel balancing machines I am familiar with needs a round hole to center the wheel. Do you need some kind of round ring adaptor temporarily mounted to it?
VaccaRabite |
Sep 28 2022, 07:24 AM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Question: How do you balance these wheels? The wheel balancing machines I am familiar with needs a round hole to center the wheel. Do you need some kind of round ring adaptor temporarily mounted to it? The RoadForce machines that use the hub to mount have a large cone and several adapters so that they can fit almost every wheel. Same could be used here. This is essentially the old aircooled VW T2 wheels done in aluminum instead of steel (and 4 lug, for a beetle instead of a bus). (IMG:http://www.914world.com/bbs2/uploads_offsite/www.jbugs.com-1435-1664371471.1.jpg) Zach |
type2man |
Sep 28 2022, 10:57 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Question: How do you balance these wheels? The wheel balancing machines I am familiar with needs a round hole to center the wheel. Do you need some kind of round ring adaptor temporarily mounted to it? The RoadForce machines that use the hub to mount have a large cone and several adapters so that they can fit almost every wheel. Same could be used here. This is essentially the old aircooled VW T2 wheels done in aluminum instead of steel (and 4 lug, for a beetle instead of a bus). Zach The 4 lug wheels the guy is asking can take a center cone adapter to balance the wheels. The picture you have is a wide 5 wheel and that one needs a center hub adapter.... |
Lo-Fi Version | Time is now: 1st May 2024 - 02:34 PM |
